BoostfoSHO 2015 SHO Build thread!
Started by BoostfoSHO, November 25, 2017, 06:39:55 PM
Quote from: BoostfoSHO on September 27, 2018, 07:02:04 AM
Does anyone here have the ATPs with turbos smart wastegates? Is it even possible to upgrade the wastegates on the ATPs? Any pictures of the set up and or idea how to properly adjust the wastegates would be appreciated.
Edit: I found out the ATP wastegate is already an updated version so no need for the turbosmart
It will require a Tune update IIRC! Provided you work with your tuner! The stock IWG actuators are 4lb springs and have a good amount of preload set from the factory.
The Turbosmart-IWG are 7lb springs AFAIK! Dunno. Best of luck and indeed look awesome.  Z
BoostfoSHO
Quote from: ZSHO on September 27, 2018, 09:42:34 AM
It will require a Tune update IIRC! Provided you work with yourTuner! The stock IWG actuators are 4lb springs and have a good amount of preload set from the factory. The Turbosmart--IWG are 7lb springs AFAIK! Dunno.  Z
The ATPs have a bent rod design on their wastegate and the turbosmart or factory wastegates doesn't that's what my main concern is. I'm sure if it installation was possible then matt could tune them. But Mike B told me the ATPs already have an upgraded wastegate to match the bigger turbos.
AJPTurbo FTW
2015 SHO PP
Air raid intake, 3bar, OBX catless downpipes, 160tstat 2. Electric exhaust cutouts, MSD ignition coil, hot pipes with Tial BOV, AJP Turbo wastegate regulator mod.
For now...
Pending install. Snow stage
BoostfoSHO
They've finally arrived. Bc coilovers with Swift spring upgrade in the front and rear spring, which I find weird because every other place I looked only offered the Swift spring upgrade for the front.
AJPTurbo FTW
2015 SHO PP
For now...
Quote from: BoostfoSHO on September 27, 2018, 07:11:47 PM
Interested to hear of your experiences with these, as I will likely have to consider these very same options (& spring upgrades) when it comes time to replacing my Megan's.
Plus I have the added weight of the sound system now to boot.
Part #'s would be great if you don't mind providing those for the community's edification. TIA. :thumb:
BoostfoSHO
Quote from: bpd1151 on September 27, 2018, 07:33:42 PM
I'll definitely follow up once I get them installed.
I got the E30BR sho coil over and the Swift strings are front: 622203 6k Swift
Rear: 62178 8k swift
AJPTurbo FTW
2015 SHO PP
For now...
At least the fronts will swap in SWIFTly for you :D  so much easier on 2013+ compared to 2010-12.  Take the opportunity to inspect hubs and clean/grease as needed.
BoostfoSHO
#261
A few more pictures. And also I scheduled the installation for next week, this I'm not messing with and installing my self since there's no alignment shop anywhere near I'll have the shop install and align it.
AJPTurbo FTW
2015 SHO PP
For now...
802SHO
Quote from: BoostfoSHO on September 28, 2018, 07:05:34 PM
A few more pictures. And also I scheduled the installation for next week this I'm not messing with and installing my selfsince there's no alignem shop anywhere near I'll have the shop install and align it.
Having a shop install is so nice.  Drop off, pick up done!  And exciting to pull up and see it outside lowered!!
BoostfoSHO
Finally installed the ATPs and changed spark plugs and brake pads. Fresh oil as well.
8 hours total with a few breaks in between. Didn't need to drop the subframe. So that was good.
AJPTurbo FTW
2015 SHO PP
For now...
Jordan
You pull the passenger axle to fit those puppies in?
BoostfoSHO
Quote from: Jordan on October 01, 2018, 12:21:45 AM
Yes, pulled the axle out and it fit right in.
AJPTurbo FTW
2015 SHO PP
For now...
Good work, Boost, and good catch, Jordan!
StealBlueSho
With the passenger axle out, how hard was it to replace the rear turbo? Honestly?
BoostfoSHO
Quote from: StealBlueSho on October 01, 2018, 09:01:00 AM
Once you remove the axle and the bracket that holds the axle... The one shown in the last picture is not hard to remove the turbo just remove the heat shield like in the front turbo then remove the bolts from the turbo to manifold and it slides right out. The front one took about hour and half to 2 hours the rear one did take about 3 then the rest was all just putting it back together
AJPTurbo FTW
2015 SHO PP
For now...
BoostfoSHO
So after my first log Matt is telling me I have a boost leak. I'm gonna go over all my clamps and connections.
do you guys have any way of pressure testing the system to test for leaks?
AJPTurbo FTW
2015 SHO PP
For now...
