BoostfoSHO 2015 SHO Build thread!
Started by BoostfoSHO, November 25, 2017, 06:39:55 PM
How many miles on your SHO.  If the numbers are getting up there, you could possibly justify dropping some for the DW injectors as a way to get new parts in there.  But full usability probably will come with a built block or all out E85 setup.
BoostfoSHO
Quote from: SHOdded on August 21, 2018, 10:27:50 AM
I've only got 42k miles... Built motor is not to far down the line maybe sometime next year... I didn't go with the xdi60 because I was told the cam can't handle full E85... So I didn't go that route maybe I should have done some more researching?
AJPTurbo FTW
2015 SHO PP
Air raid intake, 3bar, OBX catless downpipes, 160tstat 2. Electric exhaust cutouts, MSD ignition coil, hot pipes with Tial BOV, AJP Turbo wastegate regulator mod.
For now...
Pending install. Snow stage
With a properly upgraded fuel system, I believe you can run E85, if I am remembering EcoPowerParts' Flex buildout correctly.  Longevity is a completely untested factor though at least on the transverse platform AFAIK.  The big brouhaha with E85 has been variable quality at the pump, and actual pumping limitations of the stock fuel system.
Because EPP had a custom port/direct injection setup, a custom ECU was required.  Would be sticking with DI here, so I dont see the need for a custom ECU unless there are limiting tables in play.
BoostfoSHO
Quote from: SHOdded on August 21, 2018, 11:54:38 AM
Maybe it's something to look at I know he's got an upgraded fuel system for sale in his website I'll look into it later. For now the Turbos and hpfp will do till I get the built motor.
AJPTurbo FTW
2015 SHO PP
For now...
Mainly you would need, and again, I might be misquoting/not an expert, an upgraded intank fuel pump basically an auxiliary fuel pump, and the fuel lines rated for full flow e85.  Then the rest of your plans should fall into place.
BoostfoSHO
Quote from: SHOdded on August 21, 2018, 12:00:00 PM
Yes I've read about an intank boost a pump. Just haven't had much time to look into finding one.
AJPTurbo FTW
2015 SHO PP
For now...
That is why the work was done FOR you with EPP solution.  I think you can purchase the pieces separately, the entire system does not need to be.  https://www.ecopowerparts.com
BoostfoSHO
So this arrived today.
After watching the installation video and reading the instructions I didn't see anywhere where it explains how to bring the cam lobe to BDC. Any help would be appreciated. How can I tell the piston is at the lowest point ?
AJPTurbo FTW
2015 SHO PP
For now...
NOTE: The cam lobe for the fuel injection pump must be at Bottom Dead Center (BDC) for the fuel injection pump installation.
Remove the fuel injection pump roller tappet.
- Inspect the fuel injection pump roller tappet, refer to Fuel Injection Pump Roller Tappet Inspection in this section.
Remove the fuel injection pump mounting plate.
Remove the RH front wheel and tire, refer to Section 204-04 .
Position aside the RH fender splash shield, refer to Section 501-02 .
Using the crankshaft pulley bolt, turn the crankshaft until the fuel injection pump cam lobe is at BDC
StealBlue can do this with his eyes closed :D
BoostfoSHO
Quote from: SHOdded on August 23, 2018, 05:32:34 PM
Nice thank you. Good thing I'm gonna have my coworker a Ford certified tech help me with it all. And we have the Ford computer because our company has about 100 Ford fleet trucks so we got Ford techs ftw
AJPTurbo FTW
2015 SHO PP
For now...
Are they certified to turn a wrench lol.  Everybody is heavily into the computer world these days.
StealBlueSho
Quote from: BoostfoSHO on August 23, 2018, 05:42:20 PM
I have installed several DI pumps on this car... the only reason I can find they want the lobe BDC is to make it easier to install the pump....
On the bottom of the pump is a spring, when installing if the lobe doesn't have the flat side up, the pump sits higher... so it makes it difficult to tighten down. You can do it, you just need to take your time and tighten a small amount on each side of the pump to bring it down flush.
You should do that anyway when you install it... I have not yet ever set BDC and haven't had a problem yet....
BoostfoSHO
Quote from: StealBlueSho on August 23, 2018, 05:49:40 PM
You know that's exactly what I was thinking it's just to make it easier to install instead of having to fight the spring. Nice I'll be installing it when I do the Turbos and injectors. Thank you SBS
AJPTurbo FTW
2015 SHO PP
For now...
BoostfoSHO
Quote from: SHOdded on August 23, 2018, 05:45:45 PM
Oh yeah he turns a wrench all day on our trucks. He is an expert on 6.7 powerstroke I have yet to find out how hell do on the Ecoboost lol but I know what I'm doing as well. I was just confused on the BDC because I didn't see a reason why when I could just install it and push the spring down
AJPTurbo FTW
2015 SHO PP
For now...
StealBlueSho
Quote from: BoostfoSHO on August 23, 2018, 05:54:02 PM
Don't "push down " the spring... the bolts are long enough to start it without pushing the pump down...
