BoostfoSHO 2015 SHO Build thread!
Started by BoostfoSHO, November 25, 2017, 06:39:55 PM
Strange, wonder why that changed ...
Looks like the same part number tho going back to the image from RockAuto that you posted.  Amazon says it is PERFORMANCE CALIPERS, not PERFORMANCE PACKAGE CALIPERS, RockAuto says it doesn't work with the PP package.  I would call up Power Stop and ask them directly, TBH.  Not that I don't trust Fomoco :D but doesn't hurt to get the mfr to verify.
BoostfoSHO
Someone showed me these from their 2013pp but my 2015pp look like these.
AJPTurbo FTW
2015 SHO PP
Air raid intake, 3bar, OBX catless downpipes, 160tstat 2. Electric exhaust cutouts, MSD ignition coil, hot pipes with Tial BOV, AJP Turbo wastegate regulator mod.
For now...
Pending install. Snow stage
Cost cutting move maybe?
The seals definitely look orangeish on both?  The calipers mrhighcaliber got also did not have drilled pistons, but did have orangeish seals on them.
BoostfoSHO
Quote from: SHOdded on May 18, 2018, 06:20:20 AM
Could be, hell they did it on the map sensor by saving one screw maybe this is the same thing. Or could be the cross drilling made them prone to cracks like the rotors do.
AJPTurbo FTW
2015 SHO PP
For now...
I guess the seals need to be sorted out then, whether they have been upgraded or downgraded across the board.  Ugh.
BoostfoSHO
Mine were orange seals for sure... Is mrhighcaliber the owner of that picture? Cause the person that posted that on FB said their replacement didn't have cross drilled either but we didn't talk about the seals.
AJPTurbo FTW
2015 SHO PP
For now...
yes he posted those pics originally on shoforum when he was upgrading his gen 4 brakes.
Centric does list 2 different part numbers for the pistons, but of course, no specifics given
Brake Caliper Piston   Steel and Aluminum Caliper Pistons   SHO   exc Perf Pkg   Front    146.48046
Brake Caliper Piston   Steel and Aluminum Caliper Pistons   SHO   Perf Pkg   Front     146.48057
There is a price difference, no idea on availability
https://www.finditparts.com/products/7415141/centric-146-dot-48056
https://www.finditparts.com/products/7414647/centric-146-dot-48057
BoostfoSHO
So I just picked up the bad calipers from the coater so I can use as a core. They paid $350 out of the $400 bucks for new calipers. So I guess I'm out time and $50 bucks better than nothing though.
AJPTurbo FTW
2015 SHO PP
For now...
sure beats arguing and fingerpointing as a deathmatch!
BoostfoSHO
Quote from: SHOdded on May 18, 2018, 03:10:31 PM
Most definitely specially since I was expecting around $200 tops.
I called power stop to verify the seal stuff and they were no help at all. They just said it's factory rebuild. I still went ahead and ordered through Rock Auto at $330 after core return so not bad at all considering I'll have $20 bucks left.
AJPTurbo FTW
2015 SHO PP
For now...
BoostfoSHO
Quote from: SHOdded on May 18, 2018, 03:36:28 PM
We will find out soon enough LOL
Do you think the seals are really that important wether they're from a pp or non PP? I mean I don't track the car at all just maybe 1/4 here and there and some street pulls. There's a bunch of ppl running out there being non PP
AJPTurbo FTW
2015 SHO PP
For now...
Probably not under your stated conditions, but it's like having marble and then deciding to replace with vinyl (to me).  If I have a higher performance trim, I expect to maintain that accordingly.  It is possible tho that Ford has quietly done away with the differences.  But at least the seals are still different per mrhighcaliber's pics.
StealBlueSho
Makes me want to check the calipers on mine..
Quote from: StealBlueSho on May 18, 2018, 04:53:03 PM
Need those dual piston 48-mm calipers!  Z
