Ford Nav system - intermittent accuracy?
Started by metroplex, November 21, 2017, 04:59:47 AM
metroplex
My 2014 SHO has the MyFordTouch SYNC2 system, and my Navigation has been acting up a lot recently. It's showing my car is driving as much as 1/4 mile off course. And then on some days, it is spot on. I did swap out my A4 card for an A7 but the A4 card exhibits the same behavior and I've observed perfect accuracy with the A7 card on certain days.
Has anyone encountered this and found a solution?
Previously: 2014 SHO
12.4 @ 110.9 mph
Current: 2017 Fusion Sport
 When was the last time you updated the Sync System? Z
What's your Nav application version on screen ?
metroplex
I'm still on v3.8 from Nov 2015. They haven't made v3.10 available on the SYNC website. My Nav card is A7, but the original A4 does the same thing. It's at the point where it shows me driving through buildings, lakes, open fields, aubdivisions, etc. And then on some days, it is spot on.
12.4 @ 110.9 mph
       T5DG183206FSA Title: SYNC WITH MYFORD MYLINCOLN TOUCH WARRANTY EXTENSION COVERING ACCESSORY PROTOCOL INTERFACE MODULE APIMField Service Action Number:12M02 . Z
metroplex
Yes that is from 2012. I'm just wondering if there's a known issue or a known solution. I probably won't take it in.
12.4 @ 110.9 mph
Any change in tires or wheels?  Sometimes a recalibration is needed to bring the navigation back to "good".
https://www.ecoboostperformanceforum.com/index.php/topic,3836.msg78999.html#msg78999
C. I recall you having issues with the rear camera! I wonder if that would correlate with the Nav inaccuracy!
Is the the screen distorted or have any lines on it?  Z
metroplex
Yes, I'm running non stock sized tires. I recalibrated the speedometer so it is spot on. How would they recalibrate the GPSM to match the new tires?
12.4 @ 110.9 mph
jmr061
The GPSM likely needs its software updated.
Jason
16 Edge Sport
metroplex
12.4 @ 110.9 mph
Maybe 1/2 hr labor?  From the link I posted
OPERATION    DESCRIPTION    TIME
140037A Reprogram The GPSM Following The Service Procedure (Do Not Use With Any Other Labor Operations) 0.3 Hr.
I would say roughly $30.00 to be a realistic number.  Z
Heelfan1
#12
On mine it was the antenna. If the software doesn't fix it check that next. I took mine in for the same behavior and nothing fixed it and they wanted to replace unit itself. Checked online and found some issues of antenna's going bad and replaced it myself and problem solved.
For those that don't know, these systems work in multiple ways to account for black outs such as inner city or trees that would block your signal. It will use the computer to estimate where you are. That's why mine would sometimes be accurate and then show you off course. Even then it would sometimes fix itself and show you dead on, it was really strange to think it was the antenna doing this but that was what fixed it.
2013 SHO non PP LMS Tuned, 160ts, 3 Bar, CAI, DP's
2013 EX Sport, LMS Tuned, 160ts,3 Bar, CAI
2018 Raptor H.O. Ecoboost LMS Tuned
2011 F150 Harley Edition 6.2 AWD(sold)
Whipple SC, JDM Tuned 600+ hp
metroplex
Now that you mention it, the Sirius free trial that is going on now has showed me that the Sirius signal sometimes breaks up and is very sensitive to any type of interference. Sometimes the music cuts out when it is wide open. My antenna cover clicks around like it is very loose.
Do you have details on how to replace the antenna and what parts are needed?
12.4 @ 110.9 mph
Heelfan1
Quote from: metroplex on November 22, 2017, 03:25:41 PM
Sorry mine was on my truck but the same antenna. The truck was on the front above the windshield and wasn't too bad to replace. Try tasca parts they usually show a diagram of the part and how it connects. Most likely there is a connection close to the rear and wouldn't have to run a cable the entire length of the car. But with my kinda luck you would have to. Even so you will have to most likely take the headliner out or at least loose.
The truck had about a 3 ft pigtail and I could get to the bolts by loosening the headliner enough to get to it and removing the side pillar to connect the cable. Took about 30 mins on the truck.
