Quote from: SHOdded on January 01, 2018, 09:10:23 AM
Any possibility it is the knock sensors/wiring? Since knock data is master & commander.
so far we have not seen any knock spikes. it is super consistent:
-if you have NOT got on it recently .. it will generate boost correctly for a short time .. then it will start bucking, popping, after 4500+ rpm
-if you get on it right away after it has been bucking and dropping spark it does it instantly
-we see over boosting in the logs
i think there is a hole in one or both baffles. and once air gets on the other side it cant open the wastegate enough and it starts dropping spark to keep from blowing up.
