Detailing, SYNC, AV, Security, Electrical, and Lighting
SYNC, A/V, Lighting, and Security Systems
SYNC
Installed sync3 remote start heat doesn't work
Started by Chris_Flex, November 10, 2017, 08:48:48 AM
Chris_Flex
Full Member
Ecobooster
I have had sync 3 installed on my 2013 flex for few months and I have no issues I programed it myself with forscan now that it's sold out I've been using my remote start and It seems my auto heat and seat warmers are not working. Any ideas why it wouldnt? Or did I just loose it from installing sync 3? I have gone throw all the settings turned it all off and back on and still nothing
Sent from my Pixel using Tapatalk
2013 Ford Flex Ecoboost
BC Coilovers
Trans mounts
Unleashed e30 Tune
Forum Supporters
Re: Installed sync3 remote start heat doesn't work
November 10, 2017, 09:03:12 AM
The settings work though, if you do not use remote start? Probably does have something to do with Sync3 then, or could be a weak car battery.
Chris_Flex
Full Member
Ecobooster
November 10, 2017, 06:34:37 PM
The remote start works fine but after running in the cold for 10-15min the heat doesn't come on by itself
BC Coilovers
Trans mounts
Unleashed e30 Tune
Forum Supporter
Forum Supporters
Trap Speed of almost 116 mph.
November 10, 2017, 09:05:49 PM
Last Edit
: November 11, 2017, 03:08:54 PM by ZSHO
It could be a faulty seat module located under the seat. Z
Do you recall if it worked prior to the Sync 3 update?
https://www.ecoboostperformanceforum.com/index.php/topic,7439.msg125371.html#msg125371
2013 Performance Package SHO| Livernois Custom Methanol Tune|3-Bar Map|Reische-170-Stat|Full Race Tial-10psi BOV in Black|PPE-Gloss Black Hot Pipes|EPP Dual Intake in Gloss Black|PPE Catted DP|Corsa Sport Cat Back Exhaust|H&R Sport-Springs|CFM Performance Billet Valve Cover Breather In Gloss Black|Llumar 20%Ceramic window Tint|MSD Ignition Coils in Black|Extreme Roof Spoiler|Redline Fluids all around|Gearhead Intercooler|
First-SHO With Direct Port Alky-VP-M1-100%-Methanol Injection|LMS-Custom-Dyno-Tuned
@ 415whp-465wtq|
Best Trap Speed of 115.54 mph|
Gjkrisa
Ecobooster
#4
November 12, 2017, 09:37:18 PM
I feel it's probably something missing that you need to turn on did you have to do anything to turn on the remote start thru forscan?
SYNC
