Started by 396375, November 01, 2017, 10:44:38 PM
Quote from: Blackhawk on November 02, 2017, 03:29:25 PMI get wheel hop trying to launch over 2100 RPM with the tune in, might just be too much power for your suspension/tires to handle. I never cared because I figured even if it wasnt wheel hopping it would probably be spinning which would hurt my times anyways.
Quote from: ZSHO on November 02, 2017, 11:10:45 PMCheck your front/rear suspension to make sure your Struts/shocks are not shot which are prone to leaking especially @ 60K! .Z
Quote from: 396375 on November 03, 2017, 12:02:44 AMQuote from: ZSHO on November 02, 2017, 11:10:45 PMCheck your front/rear suspension to make sure your Struts/shocks are not shot which are prone to leaking especially @ 60K! .ZThey seem to be fine.I will be changing the struts and shocks next year as I am not impressed with the ride.Thanks.
Quote from: Blackhawk on November 03, 2017, 10:05:24 AMJust about to hit 60k on my car and can't do better than a 1.84 60ft, if sticky summer tires don't help I will start looking at suspension.Quote from: 396375 on November 03, 2017, 12:02:44 AMQuote from: ZSHO on November 02, 2017, 11:10:45 PMCheck your front/rear suspension to make sure your Struts/shocks are not shot which are prone to leaking especially @ 60K! .ZThey seem to be fine.I will be changing the struts and shocks next year as I am not impressed with the ride.Thanks.
Quote from: Macgyver on November 03, 2017, 09:18:29 PMThis is coming from an Auto-cross guy but drags as well. He recommends Nitto NT555R or NT05 as they supposedly have better straight line traction compared to other tires. Not cheap but highly recommended. This guy knows his stuff. I think he went to Lincoln this year for the finals.https://www.amazon.com/Nitto-NT555-Performance-Radial-Tire/dp/B01E06NYRAhttps://www.amazon.com/Nitto-NT05-High-Performance-Tire/dp/B004QL6QFM
