Quote from: BoostfoSHO on March 31, 2018, 11:05:07 PM
A no3 nozzle from devil's own is 370ml/min. 5hat should be enough to make some difference in temps right? Or is that I'm just not spraying enough?
I was/am running a 375ML nozzled for a rated 280psi pump. It was taking temps from 160f to about 110 on 105-degree days at PIR. I have not read the previous portion of the thread but i would ask what pump you are running, and what pressure. if your running a pump under 200psi you are not delivering what you might need. I in fact am upgrading to a devil's own 440ml@200 psi on my 280 psi pump. i expect to be pushing a little over 600ml when its done, it is a bit above average but not even close to a few elite members here.
have you tested the nozzle? one thing you may need to try is run out your meth, fill with DI water.. then trigger the pump with the nozzle out. if it is not a uniform spray you have a delivery issue, also some nozzles are shorter than others.. take a pic of the nozzel depth in the bung and post it here. lastly where is it planted ?
