Sorry, I was being a smartass..
It appears from the logs your pump is being lazy... I would double check to make sure there is no air in the system.. your stft and intake temps will both dip for a short time even without meth. The logs appear to indicate that your not spraying at first but then it starts at the top of 2nd iirc..
Check your pump connections, boost reference for it, and also make sure there is not air in the system.
Good luck.
