Ecoboost Performance
Troubleshooting, Maintenance, TSB Articles
PCV/Catch Cans
13 MKS PCV TSB?
13 MKS PCV TSB?
Started by StinkinLinkin13, January 27, 2018, 11:58:47 PM
StinkinLinkin13
Sr. Member
Ecoboosted
13 MKS PCV TSB?
So is there any obvious way to know whether this has been done? My 13 MKS was used with 47k when I bought it and Im not sure if it has been changed/updated. Thanks for any info.
Livernois Catless downpipes with Totalflow mufflers - AJP E40/Meth tune - Firestorm HPFP - DW 300 LPFP - Kenne Bell Boost-a-Pump - 3 Bar Map - Alky Controls Meth Injection - 160° Thermostat - EPP Hot Pipes - AEM Dryflow Filter - BOV VTA - SSM Polyurethane Torque Struts - H&R Sport Springs - 20"x10" Niche Veronas on 275/40-20 DWS06 -
Forum Supporters
Re: 13 MKS PCV TSB?
January 28, 2018, 05:28:27 AM
Well ... the valve cover would have been replaced, so instead of metal, you would see composite/black. Other than that, an OASIS report might verify.
If connectors changed (IDK) that would be another confirmation.
StinkinLinkin13
Sr. Member
Ecoboosted
Re: 13 MKS PCV TSB?
January 28, 2018, 11:07:29 AM
Thanks. Mine are still gray/aluminium. Did this problem plague all 13s or is there a certain mfg date cutoff poor is this just a result of poor maintenance? I don't have any oil in the separator and everything seems ok. I removed it cleaned it out and checked pcv valve and cleaned it out as well (nice and free rattling). Seemed ok I do smell oil at times after some hard driving but I blame it on my bov's venting to atmosphere. I did notice some oil consumption maybe 1 quart but I have been driving "pretty hard" testing all the tunes. About 1k miles since last oil change. Full synth.
Forum Supporters
Re: 13 MKS PCV TSB?
January 28, 2018, 03:26:36 PM
https://www.ecoboostperformanceforum.com/index.php/topic,3836.msg62269.html#msg62269
No dates specified that I know of.
StinkinLinkin13
Sr. Member
Ecoboosted
Re: 13 MKS PCV TSB?
#4
January 28, 2018, 04:13:13 PM
Thanks man. I read that as well. I'll just keep an eye out on it. I guess its just a matter of time.😋
Forum Supporter
Forum Supporters
Trap Speed of almost 116 mph.
Re: 13 MKS PCV TSB?
#5
January 28, 2018, 04:27:32 PM
Last Edit
: January 28, 2018, 04:46:48 PM by ZSHO
If the rear valve cover was replaced it would look somewhat newer than the front depending on the date it was installed!
Do you have any pics for comparison?
I would also check the CAC (intercooler) especially being a quart low IMO! Z
https://www.ecoboostperformanceforum.com/index.php/topic,3056.0.html
2013 Performance Package SHO| Livernois Custom Methanol Tune|3-Bar Map|Reische-170-Stat|Full Race Tial-10psi BOV in Black|PPE-Gloss Black Hot Pipes|EPP Dual Intake in Gloss Black|PPE Catted DP|Corsa Sport Cat Back Exhaust|H&R Sport-Springs|CFM Performance Billet Valve Cover Breather In Gloss Black|Llumar 20%Ceramic window Tint|MSD Ignition Coils in Black|Extreme Roof Spoiler|Redline Fluids all around|Gearhead Intercooler|
First-SHO With Direct Port Alky-VP-M1-100%-Methanol Injection|LMS-Custom-Dyno-Tuned
@ 415whp-465wtq|
Best Trap Speed of 115.54 mph|
PCV/Catch Cans
13 MKS PCV TSB?
