Trans TEMP
Started by DerricksSho, October 03, 2017, 11:43:52 PM
Quote from: SHOdded on October 07, 2017, 06:34:11 AM
Quote from: jbrown9999 on October 06, 2017, 08:29:01 PM
Sorry for the noob question but I didn't see anything mentioned for mileage when to actually change trans fluid.  I've seen 20k-50k for PTU but don't recall seeing suggestions for Trans fluid.
Ford states lifetime or 150K whichever comes first.  LOL.  I would go by old timey standards of every 5 years or 60K miles.  More frequent the harder you drive it.  So Normal conditions - 5/60.  Special Operating Conditions - 3/36.
That's a great recommendation on Manu's part.
I personally perform a double fluid drain/refill once a year, regardless of mileage.
At around $8 p/qt at the dealer, and picking up 6qts. at each swap, I can spare the hundo for solid piece of mind.
Call me crazy.
Exactly.  Cray-Cray, LOL!  Seriously tho.  I don't know about you folks, but I like to keep parts working properly as long as possible.  There is definitely fun in rebuilding, upgrading, etc. but original parts have their own charm :)
In any case, a drain/fill of trans fluid with every oil change (Mike?) is a GREAT idea.  Constantly pumping new blood into the system, taking gunk out.
polskifacet
Quote from: Colorado-SHOBro on October 07, 2017, 03:05:36 AM
Quote from: polskifacet on October 05, 2017, 11:27:23 PM
yall welcome for that bypass valve trick :p. mine are around 190s when i beat on it. have bypass valve and aux cooler.
polski- are you running the aux cooler with the 2 T fittings or just straight back to the trans from the aux cooler?
I have T fittings with the AUX cooler on the branch.
Colorado-SHOBro
Quote from: polskifacet on October 07, 2017, 11:37:27 PM
IIRC you tested it both ways correct? did it stay cooler with one way or another?
11' SHO Tuxedo Metallic black-non PP | Highly sophisticated high altitude custom AJP Turbo E30 3Bar tune w/Wastegate mod | Cat'd ceramic PPE downpipes |170 stat| SP542 plugs .028 | PP trans cooler | H&R springs | RX catch can
12.8@108 @ 6,000ft DA.
polskifacet
Quote from: Colorado-SHOBro on October 07, 2017, 11:39:17 PM
I didn't test it the other way but can confirm that the aux cooler was 180 and i could hold the pipe that goes through the radiator. I followed the stock design.
Colorado-SHOBro
Quote from: polskifacet on October 07, 2017, 11:44:16 PM
Sorry i'm seeking a little bit of clarity here. trans temps were 180 without the T's? Is there a reason you decided to decided to add the T's? Did you determine one way ran cooler than the other? or just wanted to keep it in stock configuration.
Trying to determine if it would be worth it for me to tear off the bumper and add the T's to my system since the aux cooler had no additional effect as its rigged up now.
polskifacet
Weird it really shouldn't be that much different either way. The stock cooler is part of the ac condenser coil. I don't think you will see cooler temps per se they will just be much more consistent. The thermostat won't allow temp to go under thermostat set point.
Colorado-SHOBro
Quote from: polskifacet on October 08, 2017, 11:35:18 AM
I thought the same so i plumbed the aux cooler in the simplest way possible. Starting to wonder if it does a damn thing at all or if it's the by-pass Tstat that's doing all the work. Although that's highly unlikely or FMC wouldn't have bothered with the additional cooler. The trans temps do seem more regulated and consistent but peak temps have not dropped at all post aux cooler install.
polskifacet
Quote from: Colorado-SHOBro on October 08, 2017, 12:56:07 PM
You would have to bypass the thermostat but then in the winter it would never warm up which is also bad.
