Quote from: TopherSho on September 28, 2017, 05:19:25 PM
Quote from: StealBlueSho on September 28, 2017, 04:38:47 PM
Quote from: SHOdded on September 28, 2017, 12:42:51 PM
Race gas, if no other changes made, will likely be needed.
hmmm.. Ok. I should be happy with very low 12's on pump gas with meth... I don't want to ask Brad for a race fuel tune...
Be it my whacky opinion, but you are on Brads meth tune. I have been wondering .. since the tune is not keying off of STFT, and seems to be more knock related what happens if you drop in 1:7 gallons of e85 : 97-octane ..
maybe im crazy .. but would not the drop of knock with 98 octcane\e11 help boost launch spark?
Not sure what you mean here? Yes, my widebands are in control of how much fuel is delivered while I am spraying meth. So when I spray meth, the WB's pick up the extra fueling which then cause the ECU to pull fuel thus my STFT's show fueling being pulled. Brad did attempt to tune the speed density tables on my tune but that lead to some interesting results. It clean the fuel trims up a lot, but it also caused other stuff to happen...
To be clear, I am not having knock issues. That 12.35 run I had an extremely small amount of KR towards the end of the run. Literally +1 KR for a split second which then the knock sensor started adding timing back. Its almost not enough to even talk about.
Brad can answer this better than I can, but I believe he has a global limiter on the amount of spark that can be added to my tube. I want to say it tops out at 28 degrees. How fast it adds spark can be adjusted and I am unsure if that is adjusted at the moment. Again Brad can answer this...
Helping with launch? I am not getting any KR on launch, and I almost NEVER have KR.. out of 6 runs at the track hot lapping most of them, I only had one moment of KR on the last run, again, it was not much at all...
The reason I am asking about race gas is vs pump gas getting into the 11's is the ability to turn up the tune the more. I am not knock limited at the moment on Brads tune. My car has yet to be knock limited on any tune but more fuel limited. With the meth this is mitigated by quite a bit as the purpose of meth is really to increase the effective octane with its cooling properties. I have talked a bit with Julio and his theory is that you tune your meth to prevent knock and the cooling is an added benefit.
I just see all the cars that have put down 11's are using race gas, and I am curious is 93 octane with meth has enough effective octane to crank up our cars to get to 11's...
