well now i'm flumoxxed. Snow is claiming the LED does not change color and has only one element. but that doesn't solve the pump pressure issue so now I am off to make a recorded call to the support staff and press the issue of the pump.
wish me luck..
however this does solve one mystery, if the pump has no logic, and the green led is just a green led then i should be able to drop in a replacement pump running the same pressure and re-use the exiting kit.
mailto:tech@snowperformance.net]
Sent: Monday, September 18, 2017 8:41 AM
To: Chris Beeck <cbeeck@symantec.com>
Subject: Re: [EXT] Re: Is the stage 1 100% meth compatible? IE run 100% meth no water ? thanks in advance!
Hi Chris,
it does look like it has some different colors - I dont know if that is relating to heat in the circuit or something else , but i can assure you the LED is simply meant to come on when the pump is active , there are not alarm colors in that light.
Sent: Monday, September 18, 2017 8:27 AM
Hi Chris,
The pump is able to run pure methanol - all parts are designed for this.
The green LED is not designed to turn color - if it is showing up as yellow this may be the green coloring fading or burning - it may be a bad LED running hot and overheating the coloring or the coloring did not cure properly and is fading. The light changing color is not indication of pump failure so we dont need to worry about that.
I would be happy to get a new LED light to you - we have never had one turn color before.
