I'm trying to do a little research to see if this is even possible to add on my '14 Limited. This was an option on the limited for my year, but mine did not come equipped.
Using FORScan, I enabled the heated wheel soft-touch button on the MFT. Probably the easiest part of this.
I proceeded to purchase a heated steering wheel module for $30 off ebay, and found a '14 SHO heated steering wheel for $60 also on ebay. So I'm into this for $90 in hardware.
Of course, I should have scouted around a bit first. I need to locate where the HSWM goes. I believe it's in the steering column area, but not 100% sure. I need to see if the wiring is present, and if the module gets a response from the soft-touch button. From there, I need to see if the wiring exists in the column to simply plug the steering wheel in.
My question here is:
1.) Does anyone know the location of the heated steering wheel module so I can see if wiring is present and plug it in. I want to see if Forscan can see the module at that point.
2.) Has anyone taken their OEM wheel off for a swap or other reason and observed or have photos of the various wiring connectors, and if the heated wheel wire is present regardless of if the vehicle was equipped (and was an available option for the model).
I realize I should have researched this prior to buying hardware, but I didn't want to miss out on getting a heated SHO wheel so cheap. I'm sure I could always resell. Thanks
