Blue Smoke- '13 Explorer Sport
Started by Lege1, September 08, 2017, 03:48:22 PM
Lege1
Car was making a knocking/popping noise at random times. Wife took it in to a local shop, no problem found after many miles and a few days of troubleshooting. I had them change the oil as it was a good bit overdue. After the oil change she picked up the car and began driving my son to football practice. The car began smoking from the exhaust, by this time the shop was closed for the weekend. She kept it parked until I got home three days later. I check the oil level was on the high end but good but it was very black. Air breather filter was a little dirty but no oil. Then I pulled the tube from the PCV valve to the intake manifold and oil poured out, a lot of oil. I removed the PCV and air/oil separator, they were completely full of black oil. The car goes back to the shop and they tell me I have blown turbos and it would be $2600 to replace them. I trust the guys at this shop but it is funny to me that the turbos never leaked or made noise before we brought it in. Actually they still don't make noise and still seem to be putting out boost. Any advice on how to proceed would be greatly appreciated. I can do most work myself.
Kenny Lege
2013 Explorer Sport - Stock
There should be some codes present! The oil was changed and still black!
How many miles? What color was the smoke,thanks.  Z
Lege1
Blue smoke, definitely burning oil as it was pouring into the intake. Oil is still black but he said it was much worse before. No code shows up, no warnings or lights lit.
Kenny Lege
Quote from: Lege1 on September 08, 2017, 04:12:43 PM
Blue smoke would suggest and indicates burning oil which is the most common or has high mileage, than most likely the piston rings have worn down and oil is getting by the piston as it moves down the cylinder wall. It then gets burned with the fuel, which produces the blue smoke.
If white smoke is present with a blueish hue to it its unfortunately your(Turbo seals) .
Do you have an ESP? If so would take it to a reputable Ford,preferably a Lincoln dealer for a 2nd opinion.  Z
Lege1
95,000 miles.  Driven long distances, lots of highway miles. No ESP.
Kenny Lege
IMHO would get a 2nd opinion,especially with no warranty.  Z
It could also be related to your PCV System Per TSB.
TSB #ASI-44354
NHTSA ID #10055042
Date Announced:
JANUARY 01 2014
Additional Info:
How to Fix
Summary: FORD/LINCOLN: AN ACCUMULATION OF OIL, IN LEFT HAND VALVE COVER BAFFLE, MIGRATING THROUGH FRESH AIR INTAKE OF POSITIVE CRANKCASE VENTILATION (PCV) SYSTEM, MAY HAVE ENGINE OIL IN INTAKE AIR SYSTEM COMPONENTS. MODEL 2011-2013 EDGE, EXPLORER.
2011-2013 Ford Explorer Edge Taurus Flex 3.5L & 3.7L V6 Engines: Oil Consumption Fix!
http://youtu.be/gNFXNdNIPr8
^ this.  Ford has had some issues with its PCV system, here and with the TiVCT 3.5/3.7NA on 2011-13  Edge/MKX etc.  There also fix was valve cover replacement, on the cleanside.
Lege1
Thanks guys, I think I will try to fix it myself. Could over filling with oil do this sort of thing? A guy at the shop said it was possible that one guy started filling before the other guy drained it.
Kenny Lege
Could be.  Make sure the oil level is right, check and clean all turbo piping + intercooler, and monitor.  Chances are still in favor of new valve cover, but let's see!
Lege1
Thanks, that was the plan. I'll get my car back tomorrow and start on it.
Kenny Lege
TopherSho
Quote from: ZSHO on September 08, 2017, 06:05:46 PM
TSB #ASI-44354
NHTSA ID #10055042
Date Announced:
JANUARY 01 2014
Additional Info:
How to Fix
^ 100x this  ...
Best 0-60 public road 4.35s
