- RotM Winner
- Elite Member
- Boosted
- Logged
Quote from: SHOdded on February 08, 2019, 10:40:01 AM
Try Royal Purple HPS. Yes it is not as easily available as the street SAE version, but I am pretty sure you will like it
. Amazon and Walmart both offer it.
If you are concerned about cold or hot extremes, get familiar with the viscosity and HT/HS properties of oils. Remember the timing system will be affected by unnecessarily high oil pressures, so unless you monitor the engine closely with measurements, do not go too far afield.
I believe I will try Royal Purple HPS. I just did a quick read and it sounds great.
