Do not want to Mess with the Removal of the Fill Plug/Sensor/Down Pipe ETC On your 2010 plus:.....
HOW TO Install the PTU Breather / Fill for PTU, On the Cheap...... "REVISED"
ALL YEARS ALL PLATFORMS - ALL PTU's have a Vent, they are different for Different years
and the Different Platforms, But Similar Enough that YOU CAN EASILY DO THIS
4 Ft of 5/16" Gas Line (1.49 a foot) at Auto Zone, 6.00 plus Tax
Breather Filter (I like this one - on Ebay) 6.00 to 12.50 Delivered
a bunch of these to choose from, Showing the one we installed on the 2011
http://www.ebay.com/itm/1-Pcs-12mm-Auto-Motorcycle-Cold-Air-Intake-Filter-Turbo-Vent-Crankcase-Breather-/272599379922?hash=item3f78306fd2or Remove the breather / top off the Old Breather Filler (like we Did, and use it, so no cost)
1 - 5/8" Hose Clamp or Heavy Duty Tye Wrap @ the PTU (.50 ) about
Put the car up on the Rack,
Search around till you find the Breather Hose
Remove the Breather Hose,
Install the New 4' of 5/16" Hose,
install the Clamp (good Luck tightening it) or A Tye wrap (much easier)
Route up to a Location Near the battery or @ the Fire Wall
Install the Breather Filter....
NOW Drain and Fill in Minutes, WE are Using 18 OZ of 85/140 Red Line, using Pump Filler,
takes about 10 Min Maximum to Fill, Make sure U remove the Pump from the Bottle Slowly
or the Pump from the Hose Slowly, Otherwise Pressure will Spew Gear Oil Everywhere...
"Hope this Easy Mod works for All Ecoboosters"
