Meth: less is MORE!!!
Started by ddlopes, August 18, 2017, 09:53:33 AM
StealBlueSho
At 6psi i still get spray sometimes at part throttle but any later my IATs don't drop fast enough off the line. They spool so fast.
TopherSho
Quote from: StealBlueSho on August 18, 2017, 05:41:31 PM
Same here,  if it is 1/3 or better and the 'load' is high enough I see it pop on.  I don't mind though and let it do its thing ..
Best 0-60 public road 4.35s
StealBlueSho
I have mine dialed in at 145kpa... I forget the volt I set the controller at.. but it corresponds with the boost.
bamsho
Wow, you guts are spraying meth that low.  I have mine set at 9 PSI.
StealBlueSho
Yea I just took a guess and based on daily driving where to start it. Then I datalogged a few different setting to see where the sweet spot was for me... 6 seems good for my application. I asked LMS where they recommend spraying and was given the old "every car is different, but we would love for you to come and get it dyno tuned"... bleh
TopherSho
Quote from: StealBlueSho on August 19, 2017, 07:18:50 PM
I do think 6 for me is ideal as well, it hits before there is a ton of air and starts Cooling before the rapid onset from 7-8lbs to instant 14.5-15.5 and the boost spikes.
I think a large spray down low sets the table for strong spark before higher RPMS hit.
Sent from my Nexus 5X using Tapatalk
