No Boost Ecoboost... Need help!
Started by Victorious Secret, August 15, 2017, 11:17:18 PM
Quote from: Victorious Secret on August 16, 2017, 03:00:38 PM
An I found this. My MDesign CAI inlet was broken least of my worries but thought I would share, MDesign will likely replace for free. Not sure how that happened.
Sent from my SAMSUNG-SM-G900A using Tapatalk
What's that loose 6mm hose behind the intake?
Due post some pics of he engine bay,thanks. Z
Victorious Secret
Either the meth pump or boost gauge boost reference hose. Disconnect and plugged the refrence coming off the EBC take sure the wasn't leaks between the two.
Here they are plugged back in.
Victorious Secret
Well time for a Sonic drink break then the rear turbo WG arm, thanks for all your inputs.
derfdog15
Quote from: Victorious Secret on August 16, 2017, 11:32:01 AM
Noooooo! Not what I wanted to hear derf! May be time for a billet   wheel and tial wastgates from EPP.  Hopefully they have a core in Stock. I leave town for about a month at the end of the month and don't want to leave her at home sick :(
Derf, by the way did you ever run a FORSCAN or any other device to possibly isolate the problem?
I never ran anything with forscan, just used my X4 to check for codes, and livelink to try and get logs. my issue was present with the stock tune and my AJP tune as well. In my case, I went to the track, after having some revisions done to the tune, and a few extra mods, hoping for a low 12's or magical 11's pass. previous best was a 12.87. So I expected atleast that. Ran a 12.9 on my first pass, and after that I could not get out of the high 13's/Low 14's(stock like performance). I noticed the boost gauge didnt seem to be at my commanded boost during one pass (commanded was between 15 and 16psi and it looked to be ~5PSI). Sent Brad the logs and went from there. I was kind of looking for an excuse to do upgraded turbos so the conclusion of either a turbo issue or wastegates didnt bother me too much, as it would have been a good excuse. I did notice my CAI was a bit loose during troubleshooting but that was really it. After a fresh cal download I could nail it and get to my peak boost command for a split second, at which point boost dropped off and it went into a more underboost like condition. I did talk to a local tuner/shop and they offered to diagnose but sadly I had to part ways with the SHO before that. It should be noted that in my case, I believe one of the turbos got damaged somehow, and the other was trying to work overtime to hit my commanded boost. My next step was going to be returning to stock entirely, and taking it  in to a dealership to try and get it fixed under warranty, and if it turned out to be turbos/wastegates then upgrade after. Note that my car had less than 16k on it at the time.
Quote from: Victorious Secret on August 16, 2017, 02:57:31 PM
You all think it would hurt to disconnect the battery and spray connectors with electronic spray cleaner?
Certainly can't hurt at this point.  The "bricking" of a PCM usually happens when flashing, and that is a pretty massive event.  Maybe it IS just dirt or water in the connection ...
Victorious Secret
Well, I have just about exhausted everything I can do and think the vehicle may need to go in for a professional diagnosis before I throw two new turbos at it. Below is a link to a video clip so that you all can hear what it sounds like.
https://youtu.be/OlVqgejMg3A
Have you ever checked or cleaned out your CAC(intercooler)?.Z
sholxgt
Quote from: ZSHO on August 16, 2017, 06:27:40 PM
Have you ever checked or cleaned out your CAC(intercooler)?......... hopefully its not plugged.  Z
Believe that was in his first post.
I'm looking forward to hearing the outcome and hope it's a simple fix covered under warranty!
Yeah he mentioned that he did that early on but the problem is that the ecu is telling the wastegates to stay wide open and wgdc at 0%...so to me the problem starts way before the actual wastegates...they are just doing what they are told at this point....by why are they being told to do that?
An exhaust restriction of some sort?  Was there any fuel being dumped into the cats at any point?
Victorious Secret
Nope
Victorious Secret
Lots of good info on testing the turbocharging system
Victorious Secret
Think I've found the culprit. Does this look normal? Guess I can stop denying my turbos are bad.
The other question I have is would this obvious fault cause the symptoms the PCM is doing by keeping the wastegates at 0%?
sholxgt
Nope, not normal :(  Looks like at minimum the seal has gone bad.
How many miles on the car?  Any warranty by chance?
If not, I'd say it's time for a turbo upgrade :)
