70 psi on cylinder 3
Started by MKTDave, August 15, 2017, 12:08:04 PM
Best of luck, its a hard road, but hopefully the reality turns out much rosier than it looks right now.  The engine should swap right in, there may be a few differences in sensors & smaller things tho.  The wiring harness is also a bit of an unknown between Lincoln and Ford.  It has usually been a program difference rather than hardware,  so the odds are on your side.
Izzybird
If you find yourself looking for a independent shop to do the work, Webb Transportation in Joplin has a pretty good reputation. Not exactly close to you, but it's all I got. I have never personally used them for anything since I'm in Texas, but word around the water cooler has always been pretty positive. At least be another place to get a quote from.
Wife's '15 SHO non PP
