Update: a minor hiccup in my meth experience i wanted to share because someone else will see it eventually, and i like to overshare stuff
Disclaimer! : Up front .. I am not even close to thinking this is a tune issue. So I had a bit of a conundrum about posting it in this thread. But posting a new thread seemed spammy.. so I will post it here.
What I am noticing recently is after the car sits for 8+ hours.. there is a meth hiccup under sustained load for the first few meth-pushes (IE i call a meth push a short burst of meth.. say 0-60 where the meth is on for like 3 seconds.).
I reproduced it in In a 3rd gear sweep and logged it. I feel the car is not pushing full spark and it feel sluggish until about 4000rpm and then there is power fluctuation (like a stutter.. but it is NOT a stutter), then it goes full spark and jumps in massive power.
if i do a back to back 3rd gear sweeps THE SECOND PASS does not do the same thing and it feels stupid powerful from the start.
i logged and attached it.
now my theory is this:
--I do not have a check valve and it is getting air pushed into the line, and I am getting air bubbles on the first few pushes until the line is purged. this disrupts the meth, etc. this makes the most sense. the line is subjected to 5=6 pounds of boost all the time and no meth flow is occurring. in my head over time the crack-pressure rating on the pump itself is not going to prevent air from pushing into the line. i plan on testing this eventfully by draining the meth and running water through with the collar outside the vehicle
--i have a nozzle issue.. maybe.. but to me it would happen all the time. but if i do it will be evident in the external test
--bad meth, i had a batch go bad. i somehow contaminated the VPdrum. i have been adding HEET to try to not waste what i had. i now have a full new drum and will see if new meth helps. maybe the bad meth was separating ?
anyhoo. sharing is caring.. someone might run into it ...
