Started by FiveLeeter918, August 01, 2017, 09:30:27 AM
Quote from: FiveLeeter918 on August 02, 2017, 11:13:49 AM"tip prs boost kpa" and "Boost in PSI"
Quote from: FiveLeeter918 on August 02, 2017, 11:49:37 AMgeeze, what do you mean uncorrected? This is STD not SAE correction if that's what you meant.So you got these numbers with 15.5 psi and 26 degrees of spark advance? Mind sharing a datalog?
Quote from: FiveLeeter918 on August 02, 2017, 12:16:35 PMwhy is your measured AFR stoich until after 4500 rpm?
Quote from: FoMoCoSHO on August 02, 2017, 12:18:19 PMQuote from: FiveLeeter918 on August 02, 2017, 12:16:35 PMwhy is your measured AFR stoich until after 4500 rpm?DI E85 doesn't need the enrichment straight gas requires.
