Ecoboost Performance
General Discussion
2010 SHO transmission into 2015 SHO
Started by Mo7ammed, February 20, 2019, 10:41:12 AM
Mo7ammed
Jr. Member
Ecobooster
Hi,
My transmission is long gone, I found a used 2010 trans and planning to install it in my 2015 non PP SHO, not sure if the 2010 is PP or not.
Is it going to work?
Mo7ammed
Jr. Member
Ecobooster
Re: 2010 SHO transmission into 2015 SHO
February 24, 2019, 05:38:05 AM
So, no one knows.
Weird
Forum Supporter
Forum Supporters
Trap Speed of almost 116 mph.
February 24, 2019, 06:44:46 AM
Last Edit
: February 24, 2019, 06:54:13 AM by ZSHO
I think it shouldnt be an issue,but the Trans fluid Spec is different! I'm sure others will chime in shortly. Z
2013 Performance Package SHO| Livernois Custom Methanol Tune|3-Bar Map|Reische-170-Stat|Full Race Tial-10psi BOV in Black|PPE-Gloss Black Hot Pipes|EPP Dual Intake in Gloss Black|PPE Catted DP|Corsa Sport Cat Back Exhaust|H&R Sport-Springs|CFM Performance Billet Valve Cover Breather In Gloss Black|Llumar 20%Ceramic window Tint|MSD Ignition Coils in Black|Extreme Roof Spoiler|Redline Fluids all around|Gearhead Intercooler|
First-SHO With Direct Port Alky-VP-M1-100%-Methanol Injection|LMS-Custom-Dyno-Tuned
@ 415whp-465wtq|
Best Trap Speed of 115.54 mph|
Forum Supporters
February 24, 2019, 06:52:24 PM
I would expect it to work because people are installing gen 5 engines with their gen 4 transmissions when the engines in their gen 4's go belly up. Have not heard any complaints about shift quality afterwards, but I am sure resetting the transmission adaptives (not a KAM reset) would not hurt. P/Ns from Ford may have changed over time tho.
Mo7ammed
Jr. Member
Ecobooster
#4
March 10, 2019, 08:20:42 AM
2010 transmission worked, still the TC didn't fit, 4 bolts for 2010-2012 SHO trans, and 2013 using 3 bolts TC.
they installed N/A taurus 2013+ TC, as per the mechanic it's the same as my 2015 SHO
General Discussion
