Meth ignition points... Vs high iat2 temps
Started by TopherSho, July 27, 2017, 10:01:21 PM
TopherSho
Flash point and ignition points of meth... For those running 100% meth, are you not concerned with our high Intake temps igniting the meth?
I know my intake can peak about 170+
Best 0-60 public road 4.35s
TopherSho
Quote from: TopherSho on July 27, 2017, 10:01:21 PM
bah now i am wimping out.. i will run 70:30,  at least it will require a open flame to make me a Fantastic Four member ...
sholxgt
With how many people running straight meth with zero problems, I wouldn't be too concerned.
Keep in mind that, in the strange event of a premature ignition in the intake, the motor will ingest the fireball.  As long as the throttle body is open, your chances of a meth backfire are extremely small.
I've never had meth, but I've had nitrous on multiple cars and hit some of them pretty hard.  Key is just the motors ability to ingest what you're throwing at it.  Unless you're looking to drowned the thing in meth, you should be fine.
mrhighcaliber
Well the auto ignition point of methanol is 811°F. Ethanol is like 695 and gasoline is about 500°F. (Varies based on ethanol content) Its safer than gasoline. Lol
I'm running 100% meth, pre turbo.
Sent from my Nexus 6 using Tapatalk
