February 16, 2020, 05:07:35 PM
Author Topic: 2014 SHO PP PTU fill and drain  (Read 7385 times)
Offline wraitherx
  • Full Member
  • : Hampton Roads
  • -Given: 7
  • -Received: 51
« on: July 18, 2017, 06:08:12 PM »
So I just wanted to share with everyone about my experience with draining and filling the PTU on my 14 PP.
A little background... I am the second owner of my SHO. I purchased it back in '15 with under 17k on the odo. Whether or not the fluid was changed prior to my ownership is anyone's guess but I will side on the assumption of no. I have roughly 45k on the odo now and have never changed it so I was getting anxious. I drive about 50 miles round trip from work and they are all highway miles with speeds between 65-75. On occasion when driving around town I'll open her up. Just some background of my driving habits.
My first step was I went a grabbed some 1/4" ID fuel hose from autozone, 2 1/2' worth, as well as some 5/8"-1/4" hose clamps in case I didn't have any.
The thought of how much a pain it was to fill on the PP had me thinking and after reading a couple of posts it seems like people were trying it and never really reporting back. At least not what I saw. The method I am mentioning is to fill it through the PTU vent hose after extending it out to the brake booster to which mine is located. I was able to pull the OEM vent tube off and managed to snake my arm in a way to install the new hose but was not able to tighten the hose clamp but after thinking about it I didn't want to tighten it just yet.
So I couldn't find anything to protect the O2 sensor and I didn't want it getting all over the place so I took some aluminum foil and made a make shift cover for the 02 while also routing the oil where I want it to go. Once I got the drain plug off to my surprise the gear oil was runny and not thick and building up into gunk. Once all of the fluid was drained and stopped dropping I tested out pouring some fluid into the vent tube just to ensure that fluid was going into it and sure enough it was. I left the hose clamp on the hose loosened in the event that it wasn't going into the PTU and I could pull the hose and allow the oil to drain. I couldn't find a funnel small enough so I placed the bottle into the opening of the vent tube and just proceeded to squeeze. I squeezed the bottle about 4-5 times and then after waiting about 5 seconds I would see the bottle return back to shape as well as gurgling from the vent tube draining and then I would repeat the process. It took me about 15 minutes to get 16oz's in which is what was taken out.
My oil of choice this time around was Mobile 1 and will be switching out to redline on the next go around.
All in all it's a huge relief to have it done and to know that it wasn't gunked up like some other have reported and by far a lot easier than dropping the down pipes and all the other things involved with the PP just to get to the fill.
Here are some quick vids and a picture.
Fluid drain
https://youtu.be/SBQAf8iIYJw
Me running a magnet through the fluid and picking stuff up.
https://youtu.be/3D36YVKB3t4
And then the vent tube installed and what I wiped off the magnet after running it through the fluid.
Hope this helps anyone out there!
2014 SHO PP
1999 SVT Cobra Built
Offline wraitherx
  • Full Member
  • : Hampton Roads
  • -Given: 7
  • -Received: 51
Re: 2014 SHO PP PTU fill and drain
« Reply #1 on: July 18, 2017, 06:11:53 PM »
Master cylinder. Not brake booster. Lol. Was thinking of something similar location when I had my cobras.
2014 SHO PP
Offline Vortech347
  • Sr. Member
  • : Layton, UT
  • -Given: 33
  • -Received: 114
  • Fastest Realtor.
« Reply #2 on: July 18, 2017, 06:16:00 PM »
This will likely be the method I use as well.  Thanks for the write up.
Matt H.
2013 SHO Performance Pack, Daily, AJPTurbo tuned
2003 SVT Cobra 497rwhp/491rwtq, Self tuned, Cruiser
1990 Mustang GT 570rwhp/530twtq, Self tuned, Open Track
2017 F150 XLT 5.0
Offline wraitherx
  • Full Member
  • : Hampton Roads
  • -Given: 7
  • -Received: 51
« Reply #3 on: July 18, 2017, 06:18:23 PM »
No problem at all. Glad to help the community out getting a job done easier. Like I said, I never saw and concrete proof on doing it other than the vid of the interceptor and wanted to find out for myself.
2014 SHO PP
Offline avidmotion
  • Sr. Member
  • -Given: 3
  • -Received: 75
« Reply #4 on: April 28, 2018, 07:00:21 PM »
Has anyone else tried this way? If this is the new best way it really does look simpler then fighting under the car on ramps to drain and fill. Drain still might be hard but the bummer was the fill and this seems too easy?
Offline SM105K
  • : Arizona
  • -Given: 748
  • -Received: 934
  • Land Yacht Pilot
« Reply #5 on: November 06, 2018, 06:57:41 AM »
I did this exact method.  Hardest part was getting the PTU breather off of the PTU.  I used my fingers.  Other than that, refilling it took the most time.  My fluid wasn't too bad, however the powertrain was noticeably different (smoother) with the new PTU Oil.  I used Mobil 1 gear oil.
« Last Edit: November 06, 2018, 07:48:39 AM by sm105k »
"M" 2013 SHO PP | AJPTurbo E30 Tune | GH Intercooler | PPE Downpipes | Custom Magnaflow Resonator | 3rd Cat Delete | Dicunzolo Gen2 Trans Mounts | MSD Coils | SP-542's | UPR Dual Valve Catch Can | K&N Drop In | H&R Springs | Power Stop Brakes | Curva Concept C7's | Continental DWS06 Extreme Contact Rubber
"The Fukus" 2013 Focus ST | AJPTurbo Flex Fuel Tune | Megan Racing Catless Downpipe | Boomba BOV | FSWerks Short Shifter
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • -Given: 1832
  • -Received: 3883
« Reply #6 on: November 06, 2018, 09:25:32 AM »
FYI- I would avoid using Mobil 1 Gear oil IMHO!!! @ 30K it was black which is normal but found a bit of sludge forming which was not a good sign! I recently changed over to Redline all around and the car seems much happier...
I would specifically stick with Redline or Amsoil especially for the PTU.. Some food for thought.  Z
« Last Edit: November 06, 2018, 11:54:29 AM by ZSHO »
Offline SM105K
  • : Arizona
  • -Given: 748
  • -Received: 934
  • Land Yacht Pilot
« Reply #7 on: November 06, 2018, 10:47:17 AM »
I would specifically stick with Redline or Amsoil especially for the PTU.. Sum food for thought.  Z
Good to know Z. Thank you. I have roughly 10,000 miles on my Mobil 1 "PTU" fluid.  I am at 66,000 miles.  At 70,000 I was going to change the RDU fluid, and since I will be there already, I will change out the Mobil 1 with Redline.  Pretty sure I will just end up changing all the driveline fluids yearly.
« Last Edit: November 06, 2018, 10:49:03 AM by sm105k »
Online SHOdded
  • Administrator
  • : Beltsville, MD
  • -Given: 12485
  • -Received: 4103
« Reply #8 on: November 06, 2018, 01:04:32 PM »
Offline SM105K
  • : Arizona
  • -Given: 748
  • -Received: 934
  • Land Yacht Pilot
« Reply #9 on: November 06, 2018, 02:54:06 PM »
Hope to add Amsoil SVG to this list soon
https://docs.google.com/spreadsheets/d/1oTuPwZHKoSqFLClaZrBhMh9D5vpX0VhLZrmVdLyFnbE/edit#gid=476097392
Thank you for that document SHOdded.  That is great information.
Offline Agentlongwood
  • Sr. Member
  • : Central Florida
  • -Given: 17
  • -Received: 155
« Reply #10 on: November 12, 2018, 07:53:24 PM »
I get so jealous when I see these write ups where you just have to remove the drain plug from the PTU...
2014 Lincoln MKS - It's for sale  :)
Offline HD-Rugby
  • Jr. Member
  • : SE PA
  • -Given: 51
  • -Received: 4
« Reply #11 on: July 27, 2019, 06:01:14 AM »
How would I do this on a Non PP 2019 SHO? I'd rather not take it to a Dealership. Do the Down Pipes have to come off? I want to get this done when I hit 20K to see what I have, and may go with the catted ceramic coated down pipes to handle the heat. I still need to pass the PA state inspections....
Online SHOdded
  • Administrator
  • : Beltsville, MD
  • -Given: 12485
  • -Received: 4103
« Reply #12 on: July 27, 2019, 03:44:53 PM »
All 2010-2019 non-PP SHOs will have the same basic drain/fill procedure.  No need to remove downpipes.  Follow glock-coma's writeup in the HowTo section.
Offline 802SHO
  • : Essex Junction Vermont
  • -Given: 1969
  • -Received: 937
  • Boosted
« Reply #13 on: July 28, 2019, 05:58:23 AM »
I recently did this with my 2010 and it was made simple by this suction device.  I did not find hardly any build up on the fill plug and emptied a entire quart of Redline Lightweight Shockproof gear oil in there, in a roundabout way doing my version of a flush....eventually it was pure redline oil coming out...let it stop dripping and put the plug back on.
https://www.amazon.com/Capri-Tools-Vacuum-Brake-Bleeder/dp/B00OM751EC
2010 SHO non PP, GH upgraded turbos, GH upgraded IC, EPP Hot Pipes, Alky Control Methonal Injection, Alky dual nozzle upgrade, Zex Nitrous, Dicunzolo Gen2 torque mounts, SP542 .028, 160 T, Airaid Intake, 3bar, Thunderstorm Catless Downpipes, custom stainless 2.5" double xpipe w/muffler deletes 4" quad tips, UPR Dual Valve Catch Can, Derale 10000 series 16 row trans cooler, 13+ PP Trans Cooler, Econoaid throttle Body Booster, Mickey Thompson 20x9 SC-5 Wheels, Continental Extreme Contact DW tires F: 245/40/20 R: 275/35/20, H&R Springs all around w/rear cut 1/2", 1" hubcentric wheel spacers m14 1.5 stud/lug conversion, Aeroforce Interceptor Gauge, Tuned by AJP Turbo
Highest Trap Speed 123.22 mph
463awhp 569 awtq mustang dyno 6/13/19
PB 11.368 @ 122.68 NED 10/20/19
Offline shoNoff
  • : NH
  • -Given: 216
  • -Received: 651
  • Shomu the killer whale
« Reply #14 on: July 28, 2019, 07:13:02 AM »
Iím buying one of those to do the new car. Thatís a slick little vacuum pump.
2013 SHO PP 12.51 @ 110.07 AJP tuned sold
2016 edge sport 13.92 @ 99.4 mph. slow and stock baby mobile
* Featured Topics
* Recent Topics
Re: Misfiring codes P0300, P0302 and P0306
by SHOdded | Today at 05:06:48 PM
Whoa!  Running leaded fuel or fuel with MTBE in it?...
Re: Donít see much on here about ***. Looking at them, Gearhead, and AJP
by Ls2bait | Today at 04:37:04 PM
I already have an AFE with the lid I picked up after I bought it so Ií...
Re: Rear window leak?
by TopherSho | Today at 02:37:46 PM
Yeah this is the rear REAR glass, back passenger was up for sure as I ...
Re: Roof channel trim
by TopherSho | Today at 02:22:16 PM
Ty both!.. hard to replace myself?  ...
Re: SHO whining noise?
by ZSHO | Today at 10:49:25 AM
It could be your Torque converter! How many miles on your SHO! Did you...
Re: SuperPete SHO Build record
by SuperPete | February 15, 2020, 03:15:01 PM
February updateSwitched to E40 fuel,Few revisions with MattDYNO number...
Re: Xtreme-Di HPFP35 on E40 GearHead tuned - MY REVIEW with VIDEOS
by SuperPete | February 15, 2020, 02:09:51 PM
So, to finalize this chapter, dyne is done, numbers posted and recorde...
DYNO numbers are in
by SuperPete | February 15, 2020, 02:06:52 PM
Another reason to go with GearHead...426/446All in the video belowhttp...
Re: Ford Recalls
by Leadfoot | February 15, 2020, 10:36:54 AM
FORD EXPLORER RECALL: SUSPENSION PROBLEMS IN 1.2 MILLION SUVS. Z ...
Counterfeit Ford Motorcraft Parts!
by ZSHO | February 14, 2020, 05:25:04 PM
Buyer Beware.. Don't Get Burned Buying Counterfeit Ford Motorcraf...
Re: Duel injection washing effect vs methanol-a real life look (Meth pictures wanted
by ZSHO | February 14, 2020, 03:02:17 PM
Great Topic indeed!  :)  I would @ the very least add an OCC...
Re: Post a Pic of your Ecoboost!
by SHOdded | February 14, 2020, 10:29:33 AM
Best of luck, man, hope all goes just perfect with the pregnancy &...
Re: 2013 - 2018 Flex, Taurus SHO and Interceptor & Lincoln MKT recall
by sm105k | February 14, 2020, 10:25:53 AM
Funny you say that, I am going to cut my H&R's this weekend.&...
Re: rouch brand
by SHOdded | February 14, 2020, 10:24:58 AM
You want a real intake?  Get one from ecopowerparts.com.  It...
Re: Wrapping intake pipe, numbers are out<<<
by SHOdded | February 14, 2020, 02:16:01 AM
What a joke!...
Back to top
