2014 SHO PP PTU fill and drain
Started by wraitherx, July 18, 2017, 09:08:12 PM
Isn't that the one FordTechMakuloco recommends?
6500rpm
Just a couple tips to add (PP cars).  With the car on jack stands, shield removed, it's easy to reach up and pull the factory vent tube off the nipple. You can also take it down off the right side stands when draining to get a little more out.  If you use clear hose (cheap and easy to find on Amazon), I just measure the same amount removed and leave it in the bottle and slowly squeeze it in and burp. With the clear hose you can see it go down inside and avoid spilling when you pull the hose off. I also think it's important to burp it when going in. I'm not sure if the 10-16 oz people report going back in would put any outward stress on the seals if forced in, probably more of a peace of mind thing. Easy deal on the PP cars.
2013 SHO PP in Ruby Red Metallic, GTG Billet Grills, Duraflex Racer Chin Spoiler, DriveBright LED Driving/Turn Lights,160 T Stat, MSD Coils, All Royal Purple Lubricants, EPP Gen 2 Duel Intake and hotpipes,3 bar, Gearhead AO tuned!
802SHO
Quote from: SHOdded on July 28, 2019, 11:09:17 AM
Yes it is!  It's awesome, it made very fast and easy work of draining the PTU
