I would definitely put in a one way solenoid, the closer to the nozzle the better. The pump may have a check valve, but I believe the vacuum from the intake can still draw some of the meth/water that's in the line. On my old SHO I had a trunk mounted setup with the Snow pump, once I added the solenoid I noticed an improvement in the amount of meth I was going through.
