PP shocks in non-PP
Started by polskifacet, July 05, 2017, 12:15:11 AM
I will try to get some (pics) and confirm the actual (PART Number) Needed pending if its in stock/shelf item in parts dept by Friday and is at least i can do. Z
polskifacet
Quote from: ZSHO on July 05, 2017, 07:35:23 PM
I will try to get some (pics) and confirm the actual (PART Number) Needed pending if its in stock/shelf item by Friday and is at least i can do. Z
Ok man I'll hold off on reordering then.
Here it goes and can confirm fitment for the 13+SHO with Performance Package.  Z
FRONT STRUTS
MOTORCRAFT AST12321 {#AST12256, DG1Z18124U} Info
Front Left; w/ Black Calipers; w/o Painted Calipers
MOTORCRAFT AST12323 {#AST12257, DG1Z18124W} Info
Front Right; w/ Black Calipers; w/o Painted Calipers
REAR SHOCKS X2 Same part number
- MOTORCRAFT ASH23482 {#DG1Z18125F} Info
Rear; w/o Painted Calipers (X2).
Grand Total $269.73 in (cart) with shipping and 5% Discount code applied.  Z
http://www.rockauto.com/en/cart/
[BTW added two Stabilizer Bar Links in cart if you want them].:)
MOTORCRAFT MEF353 {#GG1Z5K483A, MEF162}
Front Left
$8.73
MOTORCRAFT MEF352 {#GG1Z5K484A, MEF161}
Front Right
$8.91
polskifacet
Just ordered the full list thank you ZSHO :bow:
Quote from: polskifacet on July 06, 2017, 11:29:35 AM
Its always my pleasure to help out in any way I can and hopefully the install goes smooth without a hitch. Z
Adam best of luck.
StealBlueSho
If only there was a similar cart for a 2010 ;-)
polskifacet
hey i didnt plan the fact that my2013 is awesome :p
polskifacet
#37
Everything fits perfectly! Question I did have for Z is are the rear endlinks also redesigned? I ask because the rears have that same plastic and the pictures on tasca show it as metal with a debris guard.
Same part number for non-pp and pp so I grabbed them from the dealer already!!!
polskifacet
Also wanted to note IMO the fronts are easier that the rears. I had to do alot of heaving and heavy breathing to get the rear springs in the seat, and spinning them after i got the into the seat so the bottom hits the bump stop/ is aligned properly. From the How-to some guy said you need to pop the axel out on the fronts which is untrue. I do recommend a pass through wrench set as I had to improvise alot to get some of the nuts off.
That's awesome to hear! I installed the two front - links which seemed to be the updated version. Z
(Bottom of page.)
I figured for a few bucks why not have them changed out considering your in the same vicinity/area.
http://www.ecoboostperformanceforum.com/index.php/topic,5608.30.html
polskifacet
Night Hawk
  I went through the same thing with my non pp 2010 when I replaced the stock springs with Eibachs and went with the PP spec shocks and struts, never had any issue.
2017 Fusion Sport
GFB DivValve/165* Thermo
K&N Panel/CFM Breather
Ult Perf Int Garrett Core/MKZ oil cooler
FMS 70mm TB/ NGK .026/LMS V6 93
StealBlueSho
Quote from: Night Hawk on July 13, 2017, 10:14:47 PM
Do you still have the part numbers for the PP shocks you bought for your non-pp 2010?
Night Hawk
  I do not, however I bought them from Rock auto, and got the strut hats locally.
2017 Fusion Sport
