Forscan codes for bms
Started by jbeez, July 02, 2017, 03:02:11 PM
jbeez
Doea anyone know the forscan codes for 2014 MY to disable bms/smartcharging?
Also looking for recommendations on battery type setting, whatever the largest AH setting is considering i have added 140ah of aux batts in the trunk besides the front batt which is an agm xspower d6500.
Sorry if this is the wrong forum section, wasn't sure the most appropriate area
2014 PP SHO Darkside Metallic
K&N Panel filter, 3bar map, AJPTurbo tune, Motorcraft SP542 @.28, MSD Coils, PPE Catted downpipes, EBP Hot pipes w/ tial BOV, Tracy Lewis catch can, 170 tstat, 93 octane pump gas
I'm sure our resident Guru FoMoCoSHO and others will have some insight but see if the link below helps any. Z
http://www.ecoboostperformanceforum.com/index.php/topic,6953.0.html
Gjkrisa
I'm not sure if it works I think smart charging is off by default or the so th code looks like it
But you can find the code in f150 spreadsheet
https://docs.google.com/spreadsheets/d/1uDSQ1Z5a2Wt8-kjrSiVSlDFGFHnfeuhb3RTMVz95730/htmlview#gid=815852466
Could be placebo but since I turned on smart charging seems that battery actually charges now but also turned down when my dash cam turns off when the battery is lower then 12.5 volts instead of 12 volts
My ctek battery monitor has been saying battery around 80% instead of 60
Before would stay lower
jbeez
The way i am understanding it, its on and i want it off. Im assuming that our codes don't matchup with the ones in the f150 spreadsheet. Sync 3 vs sync2? I'm not really sure what dictates if codes will match or not from one car to the next
jbeez
Quote from: ZSHO on July 02, 2017, 03:35:25 PM
Thanks zsho, but I didn't see anything in there. Been through DanMc spreadsheet and the f150 one, its just not panning out. What i need to figure out is how to look at what flipping different bits actually do. Is there a way i can look at the actual code/config changes that take place each time i increment a value, or just change it and poke around the cars' interface manually? There has to be some backend access. How did dan come up with a list of supported batteries, how do you know that without seeing the data populated somewhere.
jbeez
The table function/area in forscan looks neat for figuring out. I think this is that backend area access. It will show me the value of the battery if i tell it thats one of the values i want to read from the module. So I can use this to trial and error bitflips. I hope the bms on/off bit will continue to be on the same memory block with the battery type. Because I seem to be able to display that. So if I can find the block that changes that, in theory the next two bits i think will be the bms on/off switch.
jbeez
just confirmed our bcm locations are different. Since I had my vin and these spreadsheets show where the vin is located for the other cars(726-09-01 starting), I decided to see where the BCM memory location for vin is on my Taurus,
It pretty much is in a totally different spot:
1  F  A  H  P  2  K  T  6  E  G  1  1  2  7  2  7
31 46 41 48 50 32 4b 54 36 45 47 31 31 32 37 32 37
BCM    726-42-01    3146    4148    50C0
BCM    726-42-02    32A3
BCM    726-43-01    4B54    3645    47D2
BCM    726-43-02    31A3
BCM    726-44-01    3132    3732    3775
and my tire size is at 726-45-01, whereas the spreadsheet has 726-12-01, or also following right after the lines of the VIN
jmr061
Send me your vin and ill see if I can help.
Jason
16 Edge Sport
jbeez
Quote from: jmr061 on July 04, 2017, 12:26:28 AM
Posted immediately above, but about to PM it, thanks :)
jmr061
Yeah that was a oversight on my part but at least we got it squared away.
Jason
16 Edge Sport
Glad to hear you were able to turn the (BMS) OFF.  :)
Jason(JMR)@ http://www.fordpimods.com/ is a Good Guy and has helped me extensively in the past. Z
