Polski Meth Kit
Started by polskifacet, June 23, 2017, 04:53:54 PM
BoostfoSHO
Quote from: polskifacet on July 21, 2017, 01:10:16 AM
Also went ahead and purchased parts for second nozzle. Based on AJP's recommendation, it needs a little more juice, she's thirsty.
On your 2 nozzle set up did you use the same size nozzles to equal a certain amount or did you use different sizes?  How much are you spraying?
AJPTurbo FTW
2015 SHO PP
Air raid intake, 3bar, OBX catless downpipes, 160tstat 2. Electric exhaust cutouts, MSD ignition coil, hot pipes with Tial BOV, AJP Turbo wastegate regulator mod.
For now...
Pending install. Snow stage
polskifacet
Quote from: BoostfoSHO on January 20, 2018, 05:40:52 PM
IIRC I'm using a 5 and 2 so 7 gph @100 psi. my pump is 300 psi so its closer to 11 @ 300 psi.
BoostfoSHO
Quote from: polskifacet on January 20, 2018, 11:52:59 PM
I've been having doubts on what to run because I've noticed the nozzles say so many cc at certain psi but my pump is also 300psi. So is throwing me off big time
AJPTurbo FTW
2015 SHO PP
For now...
polskifacet
I changed my system based on what the logs showed AJP. What fluid you run also plays a factor in size. My setup is for washer fluid which has a 30-40 % meth content
BoostfoSHO
Ah ok m planning on running 100%  I haven't yet installed it so there's no logs or anything to work with yet I just want to get everything ready for when I finally install it. I'll have to talk to Brad to see what he recommend me starting with for my meth tune. I already have his 91oct tune.
AJPTurbo FTW
2015 SHO PP
For now...
polskifacet
Quote from: BoostfoSHO on January 21, 2018, 12:14:20 PM
IIRC pure meth  needs larger nozzles
Sent from my KFFOWI using Tapatalk
BoostfoSHO
Quote from: polskifacet on January 21, 2018, 12:31:11 PM
Alright thank you I guess I have more research to do lol I have have boost juice but I'm leaving towards the 100% more
AJPTurbo FTW
2015 SHO PP
For now...
TopherSho
Quote from: polskifacet on June 23, 2017, 04:53:54 PM
Parts:
Snow Meth Pump - $144.99
Water Tank Bulkhead - meh could be better $17.99
Boost Switch - $34.99
1/4 Meth tubing - $16.94
Devil's Own Check Valve - $36.70
Low Profile Nozzle Holder - $13.60 Doesn't work too shallow
90 - $3.94
Nozzle 200ml a minute - $15.27 (I chose the Nickel Plated one)
Sealing washer - $8.21
4 way fuse holder - $10.99
Relay - $22.99 (Many choices waterproof is overkill)
Oznium Indicator LED - $4.99
Vac/Boost Port -
1/2x1/2x1/4 Tee - $12.81
90 Elbow - $6.81
5 feet of 1/2" reinforced hose
3 inches of 1/4" reinforced hose
Total - $347.28
Its a little bit over budget but I got the parts that I wanted and will fit the best IMO.
Current as of 7/18/2017
HEY POL!  How has that Check valve been ... I need one but dont want to go powered.
Best 0-60 public road 4.35s
polskifacet
SHO9987
2013 SHO Non-PP, Catless DPs, Custom 2.5" exhaust, Airraid CAI, Stock Turbo Upgrades, snow - W/M system, custom tune
lamrith
Quote from: polskifacet on February 09, 2018, 12:20:43 PM
works
That sounds.... ominous.  You have issues, things it is lacking or things you would do differently now that you have it running?
TopherSho
polskifacet
SHO9987
Quote from: lamrith on February 09, 2018, 06:18:04 PM
works
I actually felt like the devils own one way check valve worked better and easier than the snow performance solenoid.  I have used both and like the simplicity and functionality of the one way check valve.
TopherSho
Quote from: SHO9987 on February 11, 2018, 10:16:17 PM
works
Yeah the 16lb crack pressure is the key i think.  some of the others were sub 7 pounds and i can see -11 pounds on the gauge when not boosting.
