Polski Meth Kit
Started by polskifacet, June 23, 2017, 04:53:54 PM
StealBlueSho
Interested to see what your fuel pressure and AFRs looks like with this setup...
polskifacet
Quote from: StealBlueSho on July 05, 2017, 04:30:14 PM
Not sure about AFR but the FRP was bumping 2500 psi.
polskifacet
One more logging session before going to the meth head side lol. So far AJP is doing a fantastic job.
polskifacet
Figure I'll post my logs. This is the last revision before doing a meth tune. I am spraying windshield washer fluid in these.
polskifacet
So Brad wants more spray! lol car is hungry. I'm going to have to add a second nozzle which is probably half the size of the initial one. Would have had the parts today but waiting on Brads input on what size the second nozzle should be. I have enough knock suppression but the air charge is still a little warm. Ill try and see if i can mount it a bit further away from the throttle body so it has more dwell time before it gets into the combustion cycle.
Buy some 55 gal drums of the stuff.  Its about to get interesting.
polskifacet
Quote from: SHOdded on July 13, 2017, 02:44:44 PM
I do have a 55 gal drum lol and that was 1 issue. alcohol/meth floats. I had to get individual 1 gallon bottles and saw better results.
Now why does that bring up memories of Andy Griffith ...
polskifacet
Got some preliminary data on the latest tune from AJP. It's only glancing at torque so take with a grain of salt. Bumped up boost levels and still keeping FRP so I think the windshield washer fluid is doing just fine as extra fueling. There is some KR on the gear shift (when load goes up) though so I bet that is why he was saying I may need another nozzle for more knock suppression. Boy does it HAWL BAWLS though!
Niiice!  All tubing and seaks holding?
polskifacet
polskifacet
Adding latest logs for those curious
polskifacet
Got the all clear from AJP!! Excited to have a good tuner and making good a$$ power with a little windshield washer fluid! AJP AJP AJP!!
I haven't been able to post from my phone it's broke...So this is regular old winshield fluid? I will say I think there is some inconsistency in the washer fluid but overall I'm actually impressed...It's just enough fluid to keep IAT's close to 100 which basically allows full commanded spark.. But doesn't allow for too much extra spark because you aren't getting the octane of the meth since there isn't that much of it.
The 3rd gear pull looked nice but the multigear pull had some Knock retard  which makes me think the meth wasn't there for whatever reason...I'm thinking the consistency of the washer fluid. But spark levels were over 20 at one point in the 3rd gear but a little lower than that in the multigear pull due to the KR....It may be a happy medium and let the knock sensors do the work and nearing 15 psi fuel pressure is no issue.
You are actually at 14 psi at about 2600 RPM and no fuel pressure issues...Not bad for a poor mans meth kit if you want to call it that.
Also note the fuel trims long and short while spraying meth....Car should feel and sound smooth with appropriate fuel delivery.
polskifacet
regular $2 a gallon -20 washer fluid and no fancy controllers. I'm ecstatic to be at this point after dealing with that other tuning solution for so long. AJP is the MAN lol
