Just put a plug in place of that noisemaker. $3.99 @ Orielly's. There are links on the forum for the part you need.
That said you really just need to bite the bullet and get a meth tune, I know you don't want to, but peace of mind and realistically it is the only next step. Doing any other installs would be a waste of $. Your meth kit is working, you are down to 112* that is huge from where you started. Congrats btw, seriously, your setup is working well. Only way to get better is tune for the added octane and cooling. I view it sort of like adding high perf air filter and colder plugs without doing tune. you just won't see much benefit without the tune. Talk to Brad, he will get you dialed in.
If I were in your shoes I would get a tune made for your racedays. Have it setup so you start to spray much earlier. IE when you are brake boosting @ 3psi. Load the tune before you head to the track, and play around a bit on the way, pretty easy to get over 3psi boost on street, let the tune and OAR settle in on the drive, then HAVE FUN!
