August 19, 2022, 12:56:19 AM
Author Topic:  First SHO With Direct Port Methanol injection!!  (Read 72447 times)
Offline ZSHO
  • Forum Supporter
  • Forum Supporters
  • New York SHO
  • -Given: 1945
  • -Received: 4089
  • Liked:
  • Likes Given: 0
Re: First SHO With Direct Port Methanol injection!!
« Reply #105 on: May 22, 2019, 11:37:56 AM »
Bit of a Pita so far but @ least the weather is complying!
New Condenser and Gasket o-ring seal kit installed today. Z
BA5Z-19712-A - Condenser Assembly
https://www.fordpartsgiant.com/parts/ford-condenser-asy_ba5z-19712-a.html?Vin=1FAHP2KT5DG183206&Filter=()&Location=air-conditioning-condenser-compressor,,19712
9W7Z-19B596-A  - 1/2"  Seal Kit: Includes Gasket & O-Ring Condenser Assy
https://www.fordpartsgiant.com/parts/ford-kit_9w7z-19b596-a.html?Vin=1FAHP2KT5DG183206&Filter=()
« Last Edit: May 22, 2019, 04:45:09 PM by ZSHO »
Offline ZSHO
  • Forum Supporter
  • Forum Supporters
  • New York SHO
  • -Given: 1945
  • -Received: 4089
  • Liked:
  • Likes Given: 0
« Reply #106 on: May 22, 2019, 06:57:30 PM »
Gearhead Intercooler installed today and new Condenser/Gasket o-ring seal kit-ambient temp sensor accompanied by some complimentary busted knuckles!  :wounded:
I must say the GH-IC is a much heavier constructed solid unit when compared to the OEM-IC unit and well worth its weight in gold.  :)
Once again :bigthanx: to Matt over @ Gearhead for the upgraded Intercooler!  :)
I was able to take out the Redhead for a Spirited run today after install and will keep my post very limited as far as performance goes!
Time slips to follow! Z
« Last Edit: June 03, 2019, 06:16:52 PM by ZSHO »
Offline AJP turbo
  • SCT dealer and custom calibrator 3.5 ecoboost specialist
  • Vendor
  • -Given: 133
  • -Received: 1169
  • Log Warlock
  • Liked:
  • Likes Given: 0
« Reply #107 on: May 22, 2019, 11:16:59 PM »
Gearhead Intercooler installed today and new Condenser/Gasket o-ring seal kit-ambient temp sensor accompanied with some complimentary busted knuckles!  :wounded:
I must say the GH-IC is a much heavier constructed solid piece when compared to the OEM IC unit and well worth its weight in gold.  :)
I was able to take out the Redhead for a Spirited run today after install and will keep my post limited as far as performance goes!
Awesome Z...Your car does not lack fancy parts. Did you look into or inquire about a tune update from LMS for the intercooler?
SCT Dealer/Custom Calibrator
Specializing in 3.5 Ecoboost
Former:2014 PP SHO
405whp/520tq
Dyno
Tuning in progress
Offline ZSHO
  • Forum Supporter
  • Forum Supporters
  • New York SHO
  • -Given: 1945
  • -Received: 4089
  • Liked:
  • Likes Given: 0
« Reply #108 on: May 23, 2019, 06:51:07 AM »
Not to much can be adjusted besides the wastegates.Thanks buddy. Z
« Last Edit: May 23, 2019, 06:53:59 AM by ZSHO »
Offline StealBlueSho
  • -Given: 2957
  • -Received: 2854
  • Liked:
  • Likes Given: 59
« Reply #109 on: May 23, 2019, 07:01:48 AM »
This literally made me laugh....to date they still haven’t had a SHO with an upgraded IC on their rollers to tune it. And have flat out refused to remote tune for it. I sent logs from an SCT device and their device... was told they will only tune for it on their rollers...
Good luck Z! Maybe another trip to LMS in your future for proper tuning.
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 13067
  • -Received: 4255
  • Liked:
  • Likes Given: 119
« Reply #110 on: May 23, 2019, 07:12:21 AM »
I just wanna see the Redhead hit 11.5's in the 1/4, all day!
Offline ZSHO
  • Forum Supporter
  • Forum Supporters
  • New York SHO
  • -Given: 1945
  • -Received: 4089
  • Liked:
  • Likes Given: 0
« Reply #111 on: May 23, 2019, 10:17:58 AM »
To be fair I know there have been several members with this newly released IC and something that LMS should address hopefully in due time.
I also know the Dyno has been backed up for quite some time now with no readily appts available AFAIK! Z
Offline ZSHO
  • Forum Supporter
  • Forum Supporters
  • New York SHO
  • -Given: 1945
  • -Received: 4089
  • Liked:
  • Likes Given: 0
« Reply #112 on: May 23, 2019, 06:29:34 PM »
FWIW Here are a couple of PICS of the previous Fomoco OEM Intercooler & Condenser Assembly! Z
« Last Edit: May 23, 2019, 06:36:54 PM by ZSHO »
Offline craigtone
  • Jr. Member
  • Holland, MI
  • -Given: 3
  • -Received: 3
  • RAGNBUL
  • Liked:
  • Likes Given: 2
« Reply #113 on: January 07, 2022, 04:58:13 PM »
Is ZSHO still around?  Looking for help on a direct-port meth injection ...
2015 SHO (non-PP) - Off-Road DPs, K&N Intake, OBX Catback, GH AO Tune, Aux Trans Cooler, H&R Springs, PP Shocks, PI Brakes, ScanGauge 2, Amsoil Fluids
Offline Macgyver
  • Super Moderator
  • Eastern Pa.......
  • -Given: 100
  • -Received: 396
  • 2020 Red ST
  • Liked:
  • Likes Given: 35
« Reply #114 on: January 08, 2022, 05:10:56 PM »
It is a lot easier to do a single port in front of the throttle body as you probably already know.
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 13067
  • -Received: 4255
  • Liked:
  • Likes Given: 119
« Reply #115 on: January 10, 2022, 07:49:53 AM »
haven't seen Z around for quite a while.  i will try to contact him, but can't make any promises ...
* Recent Topics
Re: HOW-TO: 3.5L EcoBoost AD Transmission Mounts
by Macgyver | August 18, 2022, 12:02:06 PM
They all can help but will just add more interior cabin noise. They do...
Re: Remote functions/remote start weak or intermittent
by polskifacet | August 16, 2022, 08:24:23 PM
So far it's not horrible$170 for RFA$100 for TPM$30 for PCM$40 fo...
The Elusive Camshafts
by Ta2dResqr | August 15, 2022, 09:28:36 AM
I sent a message to Kelford Cams late last week. They are based in NZ....
Re: Polyurethane bushings interest
by timbo | August 07, 2022, 11:03:32 AM
Well, as life happens, so do delays.  The week after I returned f...
18 ecoboost performance package transmission
by Chaliasif | August 03, 2022, 12:42:10 PM
have an ecoboost 18 PF with the digital meterWhenever i shift the gear...
Re: 2014 SHO Surging / Loss of Power
by LipschitzWrath | August 02, 2022, 08:53:27 PM
Alright, today was the first time I've driven to work since the i...
Sale Ends Today! $50 off SCT X4, BDX and Power Packages
by tmcphail | July 31, 2022, 10:32:13 AM
https://mcusercontent.com/0ca62e20c7302d91c702b3697/images/4d17c3ec-c4...
Re: A little help choosing your next tire
by Night Hawk | July 30, 2022, 01:11:24 PM
  I recently ended up going with Toyos in 255, very nice stance a...
Re: Are SHO and MKS ecoboost engines identical?
by SHOdded | July 28, 2022, 05:34:01 AM
but for the noisemaker, should be.if needing a replacement, car-part.c...
Save Time & Money with an Exhaust System Kit
by RockAuto | July 26, 2022, 01:39:57 PM
RockAuto.com now offers an expanded selection of OE-Style Exhaust Syst...
