Here is a quick summary/recap after a weeks time with the newly Direct Port injection Setup!!!
The car is absolutely a (Beast)and cant wait to finally get her to the Track and have it unleashed,"Time Slips" to follow.
These are the items that are needed to complete the install for anyone interested.
6 M-15 Nozzles and 6 Adapter's for Direct Port Methanol Plumbing.
6 Cylinder Tubing Kit with B-Nuts and Sleeves.
1 IN 6 Out Distribution Block.
1/8 NPT X 3/16 Compression Fitting.
Alky Solenoid/Module,Line and Fittings.The Alky Solenoid/Module acts as a Check Valve which progresses the way the Methanol is to Travel into the Direct Port Lines.
I have been working with Julio from Alky control which has been IMHO a True pleasure to Deal with,especially with his Customer Service and Support is by far second to none in conjunction with LMS on installing and adding an additional 7TH INJECTOR at the outlet of the (intercooler) which will provide lower air charge temps prior to the intake manifold and IAT sensor.
I will have more information once it is readily available once completed and installed since my SHO was a Test vehicle on this Platform. Z
FWIW I know their are similar Kits readily available from Pro-Meth and others but they DO NOT Include/provide many of the items mentioned above in order to complete this new Direct Port Setup. Z
