March 18, 2019, 11:09:07 PM
Author Topic: "How- To" SCT Livelink datalog  (Read 43146 times)
Offline EcoPowerParts
  • How can I help you today?
  • Elite Member
  • : Phoenix
  • Thank You
  • -Given: 140
  • -Received: 1071
    • EcoPowerParts
« on: July 31, 2013, 02:28:50 PM »
Originally posted by CoreyMS
IF YOUR NOT DATALOGGING, HOW DO YOU KNOW YOUR ECOBOOST VEHICLE IS RUNNING RIGHT?
I get a lot of questions about this and it's time everyone knows how. Datalogging via the SCT Livelink program is pretty straight forward. It has a guide me function that shows you what to do, but once you've done it a couple times you realize it's not hard. This first post will show how to setup the datalogging via a laptop connected in the vehicle. I generally do not follow the guide me functions, it is just redundant.
To start, download SCT Livelink Gen II
http://www.sctflash.com/software/LiveLink_GenII.exe
Some functions can be done with the X3/SF3 connected to the computer without the vehicle, we will continue to that later.
So, you have your laptop connected via USB cable to the SCT device and the SCT device connected to your OBD-II port. Lets try to connect it. Turn the key on, OR start the vehicle.
Click "check communications". Once it connects it should look like that.
IF you are having a problem communicating disconnect everything, the SCT from the truck, the USB from the computer and the SCT, then reconnect it all and try again.
Also, in bad cases you may need to restart your computer. The drivers should install when you connect it. If you can update your tunes via "SCT Device Updater" then you should have all the drivers.
Once you get communications, Click "Vehicle Info"
If this is your first time, "Validate all PID's". Then "Select Items".
Since we are limited here on how many pictures per thread, multiple posts will be needed.
Now you select your items to log.
I have created a configuration file to make this easy, we will get to that soon.
Next, click "Configure Datalog"
The logging screen will come up. To start logging click the "start" button.
To "Stop"
If you start a second one, it will prompt you to save your datalog. Alternatively, you can click the file tab top left and go to save as, and select datalog.
__________________________________________________ __________________________________________________ ____________________
For ease of having to select your parameters I have created this Configuration file.
https://dl.dropboxusercontent.com/u/28632738/DLFConfig.cf4
To load a configuration file,
If it asks to merge this configuration with what is already selected click no.
Now, what if you don't have a laptop but you still want to datalog. The X3/SF3 has this ability, but the normal files that come with it are worthless on the Eco. Bring your device to your computer and load Livelink. You will need to load this configuration file, just as before. The difference is to be able to do this on device, the max number of parameters is 20. So I made a different configuration for you.
Load this configuration. Now, we need to Export a DLF file to our device.
Now you should be able to use the device alone to datalog, then return to the computer and Import the data, button just under export DLF.
« Last Edit: July 31, 2013, 02:31:04 PM by 4DRHTRD »
Offline Needmoreboost
  • Sr. Member
  • : SW Missouri
  • Thank You
  • -Given: 83
  • -Received: 56
  • Coyote Powered
Re: "How- To" SCT Livelink datalog
« Reply #1 on: July 31, 2013, 05:15:18 PM »
Thanks for this as I owe Torrie some logs.  Don't bother logging with just the device as the data is useless.  fyi
Might get on this now.   :bow:
2014 Mustang GT/CS: white
Offline painterpatt
  • Full Member
  • : Clearwater, Florida
  • Thank You
  • -Given: 1
  • -Received: 35
  • Ecobooster
    • Signature Autoworks
« Reply #2 on: August 03, 2013, 11:54:15 AM »
You have to use laptop to get load dont you. I'm getting knock under med accel. And Torrie couldnt read the email from sct
Koolaid drinkin, Flex drivin !!
Offline painterpatt
  • Full Member
  • Thank You
  • -Given: 1
  • -Received: 35
  • Ecobooster
« Reply #3 on: August 03, 2013, 01:47:55 PM »
And how do I do that ? New to this datalog stuff sorry
Offline breeves002
  • Full Member
  • Thank You
  • -Given: 15
  • -Received: 16
  • TCCA
« Reply #4 on: August 06, 2013, 08:18:25 PM »
Thanks for posting this! I am getting my SCT X3 tomorrow and am excited to use these great features :)
SHO Lover and Advanced Diagnostics Enthusiast
2008 Mercury Sable Premier - 3.5L N/A Duratec
  • Sr. Member
  • : SW Missouri
  • Thank You
  • -Given: 83
  • -Received: 56
  • Coyote Powered
« Reply #5 on: August 07, 2013, 06:39:35 AM »
Pretty important step for everyone running tunes.  Any tune emailed to you originally is a CANNED tune.  FYI
Offline melc
  • Jr. Member
  • : Southern California
  • Thank You
  • -Given: 4
  • -Received: 2
« Reply #6 on: October 28, 2013, 12:59:47 PM »
Very good point!! I have the following questions I am hoping to get help on.
- Is there a site that will help me understand what these PID readings mean? Example on my datalog would be a Knock Sensor reading range of -.025 to 0.75 (Good, Bad??) or a Spark Advance reading range of 3.5 - 47.5.
- Which PID are vital to datalog?
I just recently installed Torrie's W/M kit and get some logging done for him but I am really curious what my vehicle is telling me in those logs.
Thanks,
2011 Black SHO PP
Livernois and Unleashed 91 octane tunes
Unleashed W/M system
Auxiliary trans cooler
AirAid CAI Eiback Springs LED lamps inside
Offline EcoBrick Bob
  • Elite Member
  • : Naples, FL and Clear Lake, IA
  • Thank You
  • -Given: 64
  • -Received: 102
« Reply #7 on: October 28, 2013, 04:55:14 PM »
I have been datalogging since 2010 and the new LiveLink II is by far the LEAST friendly of all the SCT logging software.  The only advantage it has is that you can log more than 18 parameters at a time.  The descriptions of the actual parameters are different than the earlier "easy to understand" names.  These new LLII names are all based on specific formulas.  Also, it won't allow me to add an analog item or more (A/F from my wide-band Innovate) when I used it with my G8.  Talked with the SCT programmer who developed this back in early August and she was also surprised.  Agreed there are lots of "bugs" to work out.  I went back to LiveLink 6.5 which I find easier to use.  However all Livelink versions have their issues...
Naples, FL & Clear Lake, IA
Offline FiveLeeter918
  • Ortiz Performance - Technical Sales
  • Full Member
  • : Tulsa, OK
  • Thank You
  • -Given: 2
  • -Received: 50
  • Bewsted SHO
    • Ortiz Tuning and Performance
« Reply #8 on: June 02, 2017, 01:07:12 PM »
Hey Mike, sorry for bringing back the dead, but do you still have these config files available? The DB link seems to be dead.
- Lee
Ortiz Performance Vendor Forum | Find us on Facebook! | Order a Tune!
Offline sho in pdx
  • Newbie
  • Thank You
  • -Given: 0
  • -Received: 0
  • Ecobooster
« Reply #9 on: July 25, 2017, 10:53:08 PM »
Can I get that config file as well?
* Featured Topics
* Recent Topics
Re: Radar rear view mirror Tap!
by SHOdded | Today at 10:42:59 PM
mini usb port LOL...
by StealBlueSho | Today at 05:34:40 PM
So been busy making sure everything is GTG for the turbo/DP installati...
Re: SHO possibly Total loss
by ZSHO | Today at 04:59:46 PM
https://www.carid.com/2013-ford-taurus-grill/?filter=1&sub-model%5...
Re: Gearhead E30 vs Livernois E30 MIR 03/17/2019
by Macgyver | Today at 04:37:33 PM
Nitto NT555R 275/40/20 up front only I bet will work wonders.  I ...
Re: Connect issue see dealer on the radio, which fuse?
by SHOdded | Today at 02:58:52 PM
try fuse 14 (10 amp) in the passenger compartment fuse panel....
Re: 2013 XSport - DTC P0016 - Camshaft Position Correlation, Bank 1
by SHOdded | Today at 02:54:49 PM
It won't really save time with the intercooler install, unless th...
Re: 15 SHO F/R Brake Torque Specs
by nickstewartroc | Today at 07:21:56 AM
Nick that would be insane...DaveHere ya go!http://www.nicksmustangranc...
Info needed Catch can system
by mcrmb1 | Today at 04:09:35 AM
Has anyone tried one of the TEAM RXP 2019 HEAT EXCHANGED FULL BILLET S...
Re: BENDIX & WAGNER Rotors!
by SHOdded | Today at 04:00:27 AM
If you want to go EBCs, skip red, go straight to Yellow (or Orange if ...
Re: Hawk Street 5.0 Brake Pads!
by r1crusher | March 17, 2019, 07:49:23 PM
Just an FYI....the OE part numbers look to have been superseded (for t...
Re: Stability Control.....
by nickstewartroc | March 17, 2019, 07:36:20 PM
Got the pin run today to the IPC, and messed with the programming a li...
Re: O2 sensor
by FoMoCoSHO | March 17, 2019, 03:06:10 PM
Whats with all the Bosch hate?There is a ton of Bosch items in our car...
Re: 3.5eco transverse prone to water pump failures?
by FoMoCoSHO | March 17, 2019, 01:50:09 PM
There's at least 1 class action lawsuit regarding the transverse ...
Re: New Intercooler for Transverse 3.5L Ecoboost
by FoMoCoSHO | March 17, 2019, 01:16:39 PM
Has anyone stuffed one of these in an MKS yet?...
Re: Going Back to the 1/4!
by SHOdded | March 17, 2019, 12:42:09 PM
Well done, sir, well done!...
Back to top
