May 22, 2019, 10:46:27 AM
Author Topic: Wet Kit?  (Read 8767 times)
Offline Bharp
  • Jr. Member
  • -Given: 0
  • -Received: 3
Wet Kit?
« on: May 22, 2017, 06:32:29 PM »
I have a 2013 SHO with Livernois v10 tune, 3-bar, and 160 therm. My question is how big of a wet shot would be safe? There is not a lot of discussion on this matter it seems. I have been running a dry shot lately and it seems to be doing great. I am only running a 35 shot on it but i is responding well. Thanks for any info.
2013 SHO non PP, Livernois V10 tune, Deleted 3rd Cat, K&N drop in air filter.
12.54 best ET
111.96 best MPH
Offline Gjkrisa
  • : Fairbanks, AK
  • -Given: 885
  • -Received: 171
    • Photos
Re: Wet Kit?
« Reply #1 on: May 22, 2017, 07:54:28 PM »
There is a post in nos says he uses 75 on his flex but to watch your fuel usage to make sure your not leaning out
Offline TimmyATL
  • Full Member
  • -Given: 3
  • -Received: 15
Re: Wet Kit?
« Reply #2 on: June 30, 2017, 07:55:32 AM »
This reminds me that I need to drop LMS a email about switching my single nozzle Meth to directport Meth with 7th nozzle. Upgrading the HPFP. and adding a  dry nitrous shot at the intercooler inlet. I hope that the HPFP upgrade, stock injectors and  PCM will be able to meet the extra fuel requirements needed when the Nitrous is spraying. Thanks for reminding me LOL
13 SHO PP, Airaid intake, 170 T-stat, 3bar map sensor, Ecopower Parts hot side pipes, Turbosmart 7lb wastegate actuators, Stainless Works catted downpipes, Corsa cat back exhaust with Loudvalves exhaust dumps, Alky Control Meth Injection, LMS Dyno Meth tune. TSW Nurburgring  with NItto NTO5
Offline EcoPowerParts
  • How can I help you today?
  • : Phoenix
  • -Given: 144
  • -Received: 1112
    • EcoPowerParts
Re: Wet Kit?
« Reply #3 on: June 30, 2017, 08:02:23 AM »
I would do a wet shot, don't use the meth as fuel, it's VERY easy to tap into the fuel system for the wet shot and much safer.
I'd also do it just before the TB, no reason to waste it pre IC, if you want to do that then just do a CO2 kit spraying on the intercooler if you can make that happen with it's location.
  • : Phoenix
  • -Given: 144
  • -Received: 1112
    • EcoPowerParts
Re: Wet Kit?
« Reply #4 on: June 30, 2017, 08:07:50 AM »
Well just to double check myself I did some googling, it appears some diesel guys have had good luck pre intercooler. Wouldn't take long to put a bung pre and post IC to test your IATs and see what the difference is. I'm still leery of a dry shot though but good luck with your testing. :)
Offline TimmyATL
  • Full Member
  • -Given: 3
  • -Received: 15
Re: Wet Kit?
« Reply #5 on: June 30, 2017, 11:05:15 AM »
I figured that the Meth is already cooling the air when spraying. It looks like a pain in the ass to try and mount a CO2 set up to the intercooler. So I figured why not  put it pre intercooler and try and help the process of cooling the charge air while giving it a nice boost of power.
Offline Vortech347
  • Sr. Member
  • : Layton, UT
  • -Given: 33
  • -Received: 114
  • Fastest Realtor.
Re: Wet Kit?
« Reply #6 on: June 30, 2017, 03:33:26 PM »
I wouldn't touch a wet kit with a 10ft pole.  Direct fogger YES... One nozzle at the TB area.  Hell no.  I've seen more nitrous backfires and exploded intakes than I can keep track of.  Do not shoot fuel through a large plenum that was not designed for it.
Matt H.
2013 SHO Performance Pack, Daily, AJPTurbo tuned
2003 SVT Cobra 497rwhp/491rwtq, Self tuned, Cruiser
1990 Mustang GT 570rwhp/530twtq, Self tuned, Open Track
2017 F150 XLT 5.0
Offline luckythirteen13
  • Newbie
  • -Given: 0
  • -Received: 1
Re: Wet Kit?
« Reply #7 on: December 15, 2017, 12:46:23 PM »
i ran a 40 dry shot for a while.  i pulled 1 degree of timing from my 91 octane tune and sprayed meth and just let the factory ecu figure out the afr.  worked fine but sold the kit cause i needed money
* Featured Topics
* Recent Topics
Re: Torque PIDs...Take 2
by Gjkrisa | Today at 10:17:30 AM
All built-in Torque Real Time Monitoring gauges work.The AWD one throw...
Re: 2013 Focus st (250) engine noise
by sm105k | Today at 09:18:18 AM
Have you checked your rear engine mount? Thanks for the reply, Iím fai...
Re: LEBANON VALLEY DRAG WAY 5/25/19
by mybigsho | Today at 08:46:31 AM
Cool!! Weather is looking ok.. I'll be hanging with the factory a...
Re: First SHO With Direct Port Methanol injection!!
by ZSHO | Today at 08:37:56 AM
Bit of a Pita so far but @ least the weather is complying! Z http://i...
Re: 802SHO 2010 Build
by sm105k | Today at 06:15:02 AM
Good stuff, keep rolling....
by ZSHO | May 21, 2019, 06:33:35 PM
When push comes to shove! :D  BTW - In conjunction with spark plu...
Re: For those of you running catless on a stock catback
by 802SHO | May 21, 2019, 03:26:02 PM
Only video I have of my exhaust when it was catless downpipes to stock...
Re: A sad, sad day in the history of my SHO.....
by FLEXXX | May 21, 2019, 07:14:06 AM
That sucks, been there, not fun. ....
Re: StopTech Rotors with Akebono Pads
by DirtClodimus | May 20, 2019, 07:56:30 PM
Calipers and front pad pics added to the album. Couple nicks in the po...
Re: Project SC (1972 Celica race car with a 2.3 ecoboost.)
by Macgyver | May 20, 2019, 07:45:01 PM
That is gonna be a fun car....
Re: Had a tiny exhaust leak....
by ZSHO | May 20, 2019, 06:54:55 PM
Hmm! Here are mine! Zhttps://i.imgur.com/6UwBEPzh.jpg...
Re: New Member - 14 SHO Non-PP
by DirtClodimus | May 20, 2019, 06:10:19 PM
more so interested in in your 1/4 mile timesUnfortunately, Iíve never ...
Re: F150 Platinum FX4
by sholxgt | May 20, 2019, 04:51:02 PM
And I'm now ready for it's 1,000 mile party!  Just 150 ...
by SHOdded | May 20, 2019, 02:24:07 PM
Yeah, inevitable unfortunately.  With the shakeup of the way Ford...
MOVED: Had a tiny exhaust leak....
by ZSHO | May 20, 2019, 01:30:11 PM
This topic has been moved to Intake/Exhaust.https://www.ecoboostperfor...
Back to top
