Started by SoCalFlexin, May 19, 2017, 09:35:00 PM
Quote from: SHOdded on May 20, 2017, 05:11:48 AMThe usual cause for this message is intermittent or failed wheel speed sensor connection, such as a recent high pressure car wash, dirt/grime/water in the connector, brake service, etc. Another is a cracked tone ring. Rust has been known to occasionally fail the steering rack also, though not 100% sure it will set that message.Look at this thread, it seems to support your theory.http://www.ecoboostperformanceforum.com/index.php/topic,3965
Quote from: SoCalFlexin on May 20, 2017, 10:42:38 AMQuote from: SHOdded on May 20, 2017, 05:11:48 AMThe usual cause for this message is intermittent or failed wheel speed sensor connection, such as a recent high pressure car wash, dirt/grime/water in the connector, brake service, etc. Another is a cracked tone ring. Rust has been known to occasionally fail the steering rack also, though not 100% sure it will set that message.Look at this thread, it seems to support your theory.http://www.ecoboostperformanceforum.com/index.php/topic,3965Thank you for the reply, this helped a lot, here was what DTC mine came up withSent from my iPhone using Tapatalk
Quote from: pmezo33 on May 27, 2017, 11:24:14 AMWhat kind of tires are you running? Same four all around? Same size and tread depth too?If the "service AdvanceTrac" warning indicator light comes on in the dashboard, this could be an indication of several issues.A faulty wheel-speed sensorA faulty steering-angle sensorA faulty rotational-speed sensorAn issue with the steering rackSomething that is lodged in one of the wheelsThe AdvanceTrac system needs to be reprogrammed
Quote from: SoCalFlexin on May 27, 2017, 02:07:40 PMQuote from: pmezo33 on May 27, 2017, 11:24:14 AMWhat kind of tires are you running? Same four all around? Same size and tread depth too?If the "service AdvanceTrac" warning indicator light comes on in the dashboard, this could be an indication of several issues.A faulty wheel-speed sensorA faulty steering-angle sensorA faulty rotational-speed sensorAn issue with the steering rackSomething that is lodged in one of the wheelsThe AdvanceTrac system needs to be reprogrammedThank you for the response, the tires are all the same and the tread is equal. The code that keeps showing up is for the steering, they have put 2 new racks in the car and still no change.Sent from my iPhone using Tapatalk
Quote from: pmezo33 on May 27, 2017, 03:08:59 PMQuote from: SoCalFlexin on May 27, 2017, 02:07:40 PMQuote from: pmezo33 on May 27, 2017, 11:24:14 AMWhat kind of tires are you running? Same four all around? Same size and tread depth too?If the "service AdvanceTrac" warning indicator light comes on in the dashboard, this could be an indication of several issues.A faulty wheel-speed sensorA faulty steering-angle sensorA faulty rotational-speed sensorAn issue with the steering rackSomething that is lodged in one of the wheelsThe AdvanceTrac system needs to be reprogrammedThank you for the response, the tires are all the same and the tread is equal. The code that keeps showing up is for the steering, they have put 2 new racks in the car and still no change.Sent from my iPhone using TapatalkDo you know the specific code that keeps coming up?
Quote from: SoCalFlexin on May 27, 2017, 04:04:24 PMQuote from: pmezo33 on May 27, 2017, 03:08:59 PMQuote from: SoCalFlexin on May 27, 2017, 02:07:40 PMQuote from: pmezo33 on May 27, 2017, 11:24:14 AMWhat kind of tires are you running? Same four all around? Same size and tread depth too?If the "service AdvanceTrac" warning indicator light comes on in the dashboard, this could be an indication of several issues.A faulty wheel-speed sensorA faulty steering-angle sensorA faulty rotational-speed sensorAn issue with the steering rackSomething that is lodged in one of the wheelsThe AdvanceTrac system needs to be reprogrammedThank you for the response, the tires are all the same and the tread is equal. The code that keeps showing up is for the steering, they have put 2 new racks in the car and still no change.Sent from my iPhone using TapatalkDo you know the specific code that keeps coming up?Look on the pictures above Sent from my iPhone using Tapatalk
Quote from: pmezo33 on May 27, 2017, 06:38:04 PMQuote from: SoCalFlexin on May 27, 2017, 04:04:24 PMQuote from: pmezo33 on May 27, 2017, 03:08:59 PMQuote from: SoCalFlexin on May 27, 2017, 02:07:40 PMQuote from: pmezo33 on May 27, 2017, 11:24:14 AMWhat kind of tires are you running? Same four all around? Same size and tread depth too?If the "service AdvanceTrac" warning indicator light comes on in the dashboard, this could be an indication of several issues.A faulty wheel-speed sensorA faulty steering-angle sensorA faulty rotational-speed sensorAn issue with the steering rackSomething that is lodged in one of the wheelsThe AdvanceTrac system needs to be reprogrammedThank you for the response, the tires are all the same and the tread is equal. The code that keeps showing up is for the steering, they have put 2 new racks in the car and still no change.Sent from my iPhone using TapatalkDo you know the specific code that keeps coming up?Look on the pictures above Sent from my iPhone using TapatalkCan't make out the second picture, but for the first code (U0428), i'd start with the steering angle sensor like the code says.http://mmc-autoelectric.org.ua/manuals/eur/lancerx/2010/35/html/M135502310030200ENG.HTM#A2$16 w/out auto park and $106 w/ auto park. http://www.tascaparts.com/auto-parts/2012/ford/flex/titanium-trim/3-5l-v6-gas-engine/steering-cat/shroud-switches-and-levers-scat
Quote from: SoCalFlexin on May 27, 2017, 07:38:16 PMQuote from: pmezo33 on May 27, 2017, 06:38:04 PMQuote from: SoCalFlexin on May 27, 2017, 04:04:24 PMQuote from: pmezo33 on May 27, 2017, 03:08:59 PMQuote from: SoCalFlexin on May 27, 2017, 02:07:40 PMQuote from: pmezo33 on May 27, 2017, 11:24:14 AMWhat kind of tires are you running? Same four all around? Same size and tread depth too?If the "service AdvanceTrac" warning indicator light comes on in the dashboard, this could be an indication of several issues.A faulty wheel-speed sensorA faulty steering-angle sensorA faulty rotational-speed sensorAn issue with the steering rackSomething that is lodged in one of the wheelsThe AdvanceTrac system needs to be reprogrammedThank you for the response, the tires are all the same and the tread is equal. The code that keeps showing up is for the steering, they have put 2 new racks in the car and still no change.Sent from my iPhone using TapatalkDo you know the specific code that keeps coming up?Look on the pictures above Sent from my iPhone using TapatalkCan't make out the second picture, but for the first code (U0428), i'd start with the steering angle sensor like the code says.http://mmc-autoelectric.org.ua/manuals/eur/lancerx/2010/35/html/M135502310030200ENG.HTM#A2$16 w/out auto park and $106 w/ auto park. http://www.tascaparts.com/auto-parts/2012/ford/flex/titanium-trim/3-5l-v6-gas-engine/steering-cat/shroud-switches-and-levers-scatThe dealership still has the car and they keep telling me they are working on it and trying to figure it out. All they have changed is the steering gear so farSent from my iPhone using Tapatalk
