Quote from: mwemaxxowner on May 25, 2017, 11:31:55 AM
I swear there is no pid for commanded afr.
Also, what am I looking for when reading fuel trims? Both short and long term. What do the numbers tell me?
Sent from my Moto G (5) Plus using Tapatalk
Both of what you are looking for is under the fuel header and they are both PIDS, not DMR's
You want Lambse bank 1 and 2
For trims you want the pids... (I haven't messed with the DMRs for LTFT because there are 16 and I haven't tested them)
long term fuel trim bank 1
long term fuel trim bank 2
short term fuel trim bank 1
Trims will tell you if the ECM is adding or subtracting fuel.
I'd also add OAR Octane Adjust Ratio....this can tell you about fuel quality and can tell you if your tune is too aggressive for the fuel you are running. That one is a PID under miscellaneous.
