Quote from: mwemaxxowner on May 17, 2017, 09:54:54 AM
Quote from: TopherSho on May 17, 2017, 09:45:02 AM
as for testing the injectors the dealer might .. can't hurt to ask if it is that cylinder every time. but it will cost you a couple bills at least to find out. but if it is leaking or not actuating correctly you will get a fair amount of that cash back from the warranty.
Might make more sense to put up some cash for diagnosis vs throwing some into parts that take time and sweat to change knowing most of it will be pointless. It would be really nice to verify cylinder 6 is good to go.
I'm not scared to mess with the injectors, but I hardly ever have any time to fool with such things. My fear is really only that I will goof reinstallation in some way and cause a problem where there may be none. I've been told it's a delicate process and you have to be careful.
What do you make of WOT driving looking fine? That's a lot of why I've remained stumped.
Sent from my Moto G (5) Plus using Tapatalk
My assumption though probably/possibly wrong is un-metered air or fuel.. so while the logs 'look good' it gets weird under circumstances where a lot less fuel is being sent to the cylinder. either it is not getting all the fuel it needs, or it is getting to much fuel to that cylinder. and visa-versa if there is unmetered air same thing can cause ratio issues.
lastly focusing on one cylinder spark issues can still be a thing.. running one plug with a oem plug might not be a bad test. bit i remember you stating the issue occurred with oem plugs.
but overall you need to ensure the full system is healthy and make sure in the logs we can see that only one cylinder is the issue while we can also see the rest of the systems are in line using AJP's log.
as to 30 minutes of data, it will not fit on the device. 38 parameters will fill the device quickly. you will need to bring a laptop and slave the hand-held to the laptop and use livelink to do the capture.
