Quote from: Colorado-SHOBro on April 29, 2017, 06:11:26 PM
MiWiau did they only replace the one injector on yours? how many miles since then? wish i could get them to replace the whole set.
I asked them to change the set, but they said Ford would only cover the 1 bad injector under warranty. I decided to pass on paying extra, but it couldn't hurt to ask your dealer. I had ~32k miles on mine when the failure occurred last September, and I'm now at ~42.5k. No issues since then (knock on wood).
I had fuel in my oil, so an oil change was required. They also said warranty would only cover Motorcraft oil, even though I had just switched to Amsoil 2k miles earlier. I ended up dropping off 6 qts of Amsoil at the dealer (my expense). Just a heads up in case you are running something other than MC oil.
Also, I'm not sure if it has helped or not, but I've been adding Amsoil HP Marine TC-W3 oil to my fuel (1 oz oil for every 4-4.5 gal of fuel) at every fill-up since the injector failure in the hopes that it would help keep the fuel system better lubricated.
