e20 observation .. more HP but little TQ gains? why?
Started by TopherSho, April 24, 2017, 12:27:50 PM
lamrith
Quote from: TopherSho on May 01, 2017, 03:24:37 PM
Quote from: TopherSho on May 01, 2017, 01:11:54 AM
That last 10th of a second is $%^&ing killing me... it is all i can think about...
I think i'm bitten ..
Sending you mail AJP :P
AJP has come through with a few edits because he is awesome.  will test the 0-106mph times .. WHEN IT STOPS RAINING >:(
10% precipitation my ass..  damn PNW.
Edits are :
pushing to 15PSI with words of caution on rail pressure in the winter. (which i'm good with,  datalogged 12'f looked great)
20% less TQ reductions for lower gears.
damn rain.
Yeah the toques is a blessing and a curse...  Honestly I am having traction issues more than anything at this point, so any ore power is a waste.  AJP's tune is a real monster and if I mash throttle from a standing start all it does is spin thru 1st, then chirp second but car is so slow actual mph that it then drops rpm.  It pulls out from there, but just lot of stress and makes the car not feel fast.
I hear you on weather!  Dreaming or warmer days with good dry pavement!!
f8tlSHO
My dyno revealed 14psi on e20 is better than 15psi on e20... and the 14psi tune was loaded on dyno..... about same peak power, but higher rpm 14psi made more
2013 Non PP Unleashed 93 E20 3 Bar Tune, K&N drop in 12.491 @ 110.96 120's IAT
Now tuned by ajp...looking to go faster
E30 tune on14psi full weight including 2 child seats,race like a real street car.
12.433 @110.8 140's IAT; Mustang Dyno 332hp / 386tq
StealBlueSho
Quote from: lamrith on May 01, 2017, 03:32:28 PM
Edits are :
damn rain.
Sounds like your AWD system is not working... or your tires are shot...
TopherSho
#63
Edits are :
damn rain.
Up to now I have not seen a single TQ error.. *so far*,  and also have not had issues with full tire spin from start to the end of 1st (AJP's TQ control is very precise).  So I am hopeful this sill be the tweak that breaks under 12.99 and takes some of the edge off the damned drop in MPH during 1-2 shifts.
I think that is where my 12.99 is getting killed, the loss of MPH on 1-2 shift...  On some runs to I have seen it clip 4-mph off of my speed before it starts accelerating again.  Decelerating and then having to overcome negative inertia is probably my issue.
The extra boost is just squeezing that rock a bit harder.  I do not expect the extra tinny bit of extra boost to add much more than a 'smidge' on the back end of the curve .. but every little thing counts at this point.
were at 200ms on the shifts so i do not think we can go any lower on shifting speed.. and i am afraid to try :P  .. binding the ptu with 440wtq just sounds crunchy and expensive.
Best 0-60 public road 4.35s
TopherSho
Quote from: f8tlSHO on May 01, 2017, 03:43:40 PM
I'm pump-92 with the default 10% .. well see if there is any negative effects.  I imagine it will be a wash at low RPM's, and only a tiny bit beneficial at mid.. and no help at all at high rpm.
f8tlSHO
Quote from: TopherSho on May 01, 2017, 04:34:58 PM
Might create more heat... more heat is not good..
f8tlSHO
Anyone that has the flywheel tq functioning.... can you please give me your strategy so I can get sct to compare my strategy so they can add it to mine.. thanks!!!
lamrith
Quote from: f8tlSHO on May 01, 2017, 05:43:39 PM
The Screenshot of my SCT below is with it running KHDK4 strategy for my car.
Quote from: lamrith on April 28, 2017, 12:52:18 PM
Following up on the torque data options...
Pulled PID/DMR from car lastnight and made a config file for SCTx4 and ran it in guage mode this morning.  I found 4 Torque entries in the list that seemed relevant (lots of datapoint with torque in name for various things)  Most are pterry clear what unit they are in, the last one has me baffled though given the max number relative to the others in picture below.  I make a bit of an assumption on unitS of measure given known output of these cars and the conversion factor...
PID: READING = CONVERSION
ENGINE BRAKE TORQUE: 607.26NM = 447.892lbft
ENGINE TORQUE FLYWHEEL: 447.41lbft = 606.6065NM
TORQUE AT FLYWHEEL: 649.23NM = 478.8475lbft
WHEEL TORQUE CONVERTED TO ENGINE TORQUE:837.29NM? = 617.5534lbft? (-20%drivetrain nets 494lbft)
Could the 1st three actually be at the wheels numbers and the last is at crank? I have seen a number of people with similar tunes running in the mid 400lbft's to wheels.  Last number with 20% loss ends up right @ 494lbft which would be high, but within range?...
What I am really curious about is how it is coming up with these numbers.  I hope to be able to get on a dyno here sometime soon and log these DMR's during pulls to get some real world comparison data.  I just have not been able to find a awd dynojet locally, they are all mustang or dynapack.
No need to dyno, flash back to stock and see which one shows 350 lb ft or it's nm equivalent. Once you have that you can calculate drivetrain loss since the pid also reads negative torque.
f8tlSHO
Thanks guys, the sct guy said he needed to see a strategy with it activated so he could create a ticket for the engineers to add it to my strategy.
f8tlSHO
Quote from: lamrith on May 01, 2017, 06:03:08 PM
are all 4 of these dmrs needed? Which one is everyone using?
lamrith
Not needed.  I just picked everyone I could find to compare.  I think top one is in Nm, second in hp and both represent wtq.
Sent from my SAMSUNG-SM-G935A using Tapatalk
TopherSho
Quote from: f8tlSHO on May 01, 2017, 06:38:05 PM
did you ever hear back?  my ticket is in limbo ..
f8tlSHO
Quote from: TopherSho on May 02, 2017, 10:09:37 AM
No they are only open until 6pm.. I'm going to call back after work. What did they tell you?
