e20 observation .. more HP but little TQ gains? why?
Started by TopherSho, April 24, 2017, 12:27:50 PM
TopherSho
So I have been looking at a few dyno sheets form the regulars,  Steel,AJP,FoMo,Lt8  etc and I see a odd pattern, (odd to me that is).
Going to E20, ups the HP by a really good amount, allows +6 or so more spark than me... but then barely nudges the TQ meter?
I find that super odd.  Especially when Steel and others then run the 1/4 mile several tenths faster on E20 vs pump which suggests to me its more than HP being gained.
Can someone offer some insight on that?
Best 0-60 public road 4.35s
It's both...
I have a ton of torque, there is a graph around here somewhere.
Since our ECM calculates torque and outputs the data, I really don't see a need for dynos as they are subject to operator error and I see stock vehicles putting down numbers that just aren't possible so that tells me there are possibly large variations between the dynos themselves. Maybe I'm wrong and a tuner has seen more than 350 lb/ft commanded on the OEM calibration but I seriously doubt it and I suspect someone would have mentioned it.
Don't get me wrong, if you dyno on the same dyno to show changes from mods, that makes sense but as a comparison tool between different cars and dynos I think its a waste of money.
For me, timeslips and flywheel torque DMR is a better apples to apples comparison...If only we could get DMRs functioning for everyone.
TopherSho
Quote from: FoMoCoSHO on April 24, 2017, 01:07:58 PM
It's both...
I'll have to hook the laptop and SCT back up to the car and see whats available.. i cannot recall if my firmware was SCt supported for DMR or not.
derfdog15
I dont have a link on me right now, but on my car, the stock tune vs. E20 tune that I tested, Horsepower stayed the same, but torque was dramatically higher with my E20 tune.
f8tlSHO
Quote from: derfdog15 on April 24, 2017, 02:59:33 PM
My "stock" timing/boost on e20 fuel was 290hp/290tq at wheels. My e20 tune on 14psi was 332 and 386.. so I would say it's the tq that jumps not hp. And the range of where the power comes in is huge... my car made peak tq at like 3100rpm I think...peak numbers don't mean a thing if they don't come in until 5500rpm
2013 Non PP Unleashed 93 E20 3 Bar Tune, K&N drop in 12.491 @ 110.96 120's IAT
Now tuned by ajp...looking to go faster
E30 tune on14psi full weight including 2 child seats,race like a real street car.
12.433 @110.8 140's IAT; Mustang Dyno 332hp / 386tq
TopherSho
Sadly I do not have DMR's for my firmware.  I put in a query to SCT, however I am not holding my breath..
TopherSho
It's both...
SCT has replied and asked what DMR I would like to enable!   woot!
can you tell me what the title of the DMR is you recorded your Nm reading from ?
f8tlSHO
Quote from: TopherSho on April 27, 2017, 12:18:43 PM
It's both...
I need to do the same!!! Cause I couldn't get mine to work either
TopherSho
Quote from: f8tlSHO on April 27, 2017, 12:21:53 PM
It's both...
kevin czajkowski from SCT is who responded with DMR to add...
f8tlSHO
Is that specific to your vehicle? How is it added?
TopherSho
Quote from: f8tlSHO on April 27, 2017, 12:46:26 PM
Based on the technical description of a DMR, and my understanding of DMA in computers,  it will most likely be individual to the firmware revision.   Once enabled on mine, anyone with a DMJKBLA strategy /  AU7A-14C204-GTC SWPN can verify all the pids\dmrs in livelink and have it available to log.
lamrith
#11
I am tracking 2 torque dmrs that I saw available in my strategy (khdk4).  Picture attached with names.  Sorry laptop screen not showing well..
Sent from my SAMSUNG-SM-G935A using Tapatalk
EDIT: ENGINE BRAKE TORQUE  and ENGINE TORQUE FLYWHEEL
TopherSho
lamrith
NP, I would like to know the difference between the two actually.  One obviously is flywheel, but what is the other one and how does it relate....?
TopherSho
Quote from: lamrith on April 27, 2017, 02:50:23 PM
From this wordy jaunt ..  http://www2.egr.uh.edu/~mece2hv/Papers/4.pdf
Brake TQ = TQ at the Brakes/wheels.  So some loss is assumed and calculated.
Flywheel TQ = would be more of a estimation of a Engine Dyno.
