Started by Half-Fast, April 04, 2017, 09:13:43 AM
Quote from: Half-Fast on April 04, 2017, 04:10:23 PMQuote from: donky4444 on April 04, 2017, 03:28:53 PMThis is great to hear. I'm considering taking mine to a DE day with some friends that run their Porsche's just to have some fun. I have a 2014 PP. I do have a few questions for you though:1. did you run the stock brake set up, pads, rotors and fulidI ran stock fluid and OEM pads. I didn't push it in the braking zones all that hard, but it did do better than I expected for a fat pig of a car. I would highly recommend having the system flushed with fresh fluid, and pads should have more than 50% life left on them, the more the better. Quote2. did you run in full auto or paddle shiftI used the paddle shift. Having the trans auto downshift in the middle of the turn unsettles the car, and near the limit that could be a bad thing. The track I was on, is pretty slow as tracks go, I was able to do the entire track in 3rd and 4th, only needing 4th for a little bit on the straights. QuoteI know we had a member that auto crossed his and he ran some racing pads but I can't recall what brand he ran. I know they offered a few different versions for our car based on how hard you planned on pushing and they differed based on operating temp range.I know Hawk makes a few heavy service pads, but I am not sure if they are better or worse than the PP pads. The problem with the heavy service pads is they work great when hot, but are the suxor on the street when temps aren't in their "butter zone". You will destroy rotors if you use race pads on the street.QuoteThanks in advanceAnytime. I am glad to answer any questions anyone has. I put myself in the right seat of a novice driver and teach them how to go fast because I want to see more people out there on track having fun. My Sunday student was a first timer with a 750hp Z06, and he wanted to use all of it. Quite a ride...
Quote from: Half-Fast on April 04, 2017, 10:14:14 AMQuote from: AJP turbo on April 04, 2017, 09:48:54 AM220 is barely above normal operating temp...i thought the bypass valve for the cooler doesnt even open until close to 200...alternatively if the trans fluid temp was 150 im not even sure if thats warm enough to be in the sweet spot of trans fluid tempsFair enough. I am open to learning more. I based my decision on where to set the redline on the gauge on what this guy says http://transmissionrepairguy.com/transmission-overheating/ He could be wrong of course, but his numbers seem to jive with what others have said according to the internets. In summary, the link says under 175 is fine, 175 and over you start to shorten the life of the fluid. Over 220, varnish starts to form, over 240 and seals start to harden, it gets worse from there. For reference, the temp was 150-154 at 60 mph for the 44 mile trip home. Ambient temp was in the 60's, and on hills it would go up a bit, then drop back down after the mountain. QuoteIn fairness how many 45k cars are up to the task of hot lapping a road course?...i wouldnt want it to be track ready...kind of like when they run the slalom in minivans and trucks in motorweek lol who cares...i juts dont see the fun in taking the 4400lb sho on the track ...i guess if its all you have then i could see itAs an instructor, tracking what you drive is a fantastic way to learn what your car will do in an extreme situation. This translates to the street and may help you get out of a tight situation as you will know what to expect. Is anyone going to go out and buy a SHO for track days, not likely, and not my choice either. I'd say that the guy who use to track his Tercel was told the same thing (until he drove the piss out of it and surprised everyone). I much prefer to race my Honda Accord.. Running an uncommon car fast is a reward of it's own.
Quote from: SHOdded on April 19, 2017, 06:56:56 AMMight want to PM him, he's keeping pretty busy.
Quote from: metroplex on April 19, 2017, 12:28:43 PMGroup IV base stocks will probably get just as hot but may or may not breakdown quicker.
Quote from: AJP turbo on April 19, 2017, 12:14:46 PMYou mention you have all stock fluids...i cant think of a scenario why anyone would take their car on a track unless they wanted to document at what point failures or symptoms of an abused car.I would call amsoil and ask if the temps you are seeing is a problem...and you might want to consider using a real synthetic fluid such as amsoil signature series...group iv oils are completely different and seemingly indestructible so i would think amsoils signature series atf 220 is nothingMaybe you should get some good oil in the trans engine and ptu and the temps may not even get that high
Quote from: AJP turbo on April 19, 2017, 01:37:28 PMTo be honest im not sure what the operating temp of the 6f55 is..but i wouldve guessed 200I cant see it being much lower than that considering the trans fluid runs through the radiator and with a stock thermostat the coolant is is at least 190 ish
Quote from: 92BlackGT on April 20, 2017, 03:40:24 AMthe trans cooler is on the cool side of the radiator, so the coolant will cooler than 190
