Fusion,Escape,Fiests,MKZ,RECALLS!!
Started by ZSHO, April 01, 2017, 07:06:14 AM
FORD FUSION GEAR SHIFT RECALL EXPANDED
Ford recalls 273,000 model year 2013-2016 Fusions after property damage and injury reports. Z
MAY 15, 2019 — A Ford Fusion gear shift recall has been issued for about 273,000 cars to fix transmission cable and gear shift lever problems, with more than 259,000 of the model year 2013-2016 Fusions recalled in the U.S.
The cars are equipped with 2.5-liter engines and gear shift cable bushings that attach the shift cables to the transmissions. According to information from Ford, the bushings can degrade and cause the cables to detach from the transmissions.
The problem will cause the gear shift indicator to fool a driver into believing the Fusion is in one gear (or PARK), while the transmission may be in a different gear.
A detached shift cable will allow the driver to move the shift lever to PARK and remove the ignition key even though the Fusion isn't in PARK, creating the perfect rollaway condition.
http://m.carcomplaints.com/news/2019/ford-fusion-gear-shift-recall-expanded.shtml
FORD FUSION AND LINCOLN MKZ RECALLED FOR SEAT BELT-RELATED PROBLEMS
Ford recalls 108,400 vehicles after someone was injured by a seat belt cable failure. Z
AUGUST 15, 2019 — A Ford Fusion and Lincoln MKZ recall has been issued for 108,400 vehicles because the seat belt assemblies may fail.
The 2015 Ford Fusion and 2015 Lincoln MKZ vehicles have seat belt anchor pretensioners could degrade the strength of the cable to the point occupants wouldn't be restrained.
This may occur on both front seat belt anchor pretensioners due to heat generated when the pretensioners activate.
So far Ford believes one injury is related to the defect, a problem that can allegedly be fixed by applying a coating to protect the cables when the pretensioners deploy.
The automaker says 103,374 vehicles are affected in the U.S., about 4,000 vehicles are recalled in Canada and Mexico is home to about 1,023 affected Fusion and MKZ vehicles.
The 2015 Ford Fusions were built between August 1, 2014, to January 30, 2015, and the 2015 Lincoln MKZ vehicles were manufactured from August 1, 2014, to November 21, 2014.
Affected customers may call 866-436-7332 and refer to recall number 19S25
http://m.carcomplaints.com/news/2019/ford-fusion-lincoln-mkz-recalled-seat-belt-problems.shtml
FORD RECALLS EDGE, FUSION, LINCOLN MKX AND LINCOLN MKZ
About 99,000 Ford vehicles may suffer power steering problems from corroded bolts. Z
Ford's number for this recall is 19S26
http://m.carcomplaints.com/news/2019/ford-recalls-edge-fusion-lincoln-mkx-lincoln-mkz.shtml
