Picked up a Tremor, lots of fun going to be happening soon
Started by EcoPowerParts, March 13, 2017, 11:43:28 AM
Raining in Phoenix, not often so time for a truck pic
The Truck looks Awesome Mike!  :thumb:
Had to get a little more aggressive with cutting and rolling so I can stop cutting the sidewalls. Bats, bars, saws and bags, every mm needed. I even had the wheels shaved 5mm in the pad for +35 offset.
Stereo progress continues!
Custom one piece driveshaft finally showed up
Aluminum 1 piece vs steel 2 piece. The 2 piece won't survive 2 step and trans brake launches that will start happening soon. It's finally under 100 here. :)
ToMang07
I have a 5" 1-piece on my 350 Diesel... they are NICE!
Looks awesome so far!
~Tom~
2013 SHO - Stage 3 Snow Performance Meth, (2) SCT X4 with Unleashed, 3 Bar Map, MSD Ignition Coils w/Colder Plugs 170*TS, EcoPowerParts Hot Pipes & Tial-Q BOV) Stage 3 Motorsports Catless Downpipes 3" Cat-Back Exhaust, JLT Oil Separator, H&R Sport Springs, K&N CAI, Drilled and Slotted Rotors w/EBC Pads
Almost done, had to pick up a new remote, should be done this week, still trying to figure out the Raptor steering wheel.
Center came out awesome
Almost time to finish the suspension
Stereo is installed, I'm playing around with a ton of the settings but getting close.
Also put in the 2015+ clockspring to work with the 2017 Raptor steering wheel, this time also installed the new air bag. No codes or issues but not all buttons work and definitely not as expected. I ordered a 2015+ SCCM as that will hopefully have what I need to get the buttons all working.
Next will just to program it via Forscan
Video of setup as of tonight with steering wheel installed
http://youtu.be/_jt7d2brAs8
New taillights and third brake light
802SHO
Quote from: EcoPowerParts on November 01, 2018, 08:48:47 PM
Looks so mean!  Beautiful truck!
New EcoBeast badge overlay. Also got a picture of the wife's super duty and my truck both clean at the same time
