Picked up a Tremor, lots of fun going to be happening soon
Started by EcoPowerParts, March 13, 2017, 11:43:28 AM
Mike, how much did the conversion parts run?
After experiencing Sync 3 in the CMAX I'd love to convert the Lincoln.
Quote from: FoMoCoSHO on June 02, 2018, 01:04:07 PM
Under $700
Just finished (mostly), I didn't realize I would need the 4Dtech USB harness and faceplate adapter but I just ordered them.
I used the following codes for my Tremor:
7D0-01-01 2A21 0406 002E
7D0-01-02 0289 0600 0A75
7D0-02-01 5553 0103 40C6
7D0-02-02 8200 0000 005D
7D0-02-03 0005 E1
7D0-03-01 0000 0103 00DF
7D0-04-01 0100 1100 0AF8
7D0-04-02 0004 E1
7D0-05-01 198C 198C 2E55
7D0-05-02 0EEC
7D0-06-01 805E
7D0-07-01 0A00 3300 001C
7D0-07-02 0000 0EF9 00E7
7D0-07-03 0056 5684 0011
7D0-07-04 694B
Always a bit of fun getting the right hex values in place when doing these upgrades :D
FearlessAZ
Looks like so much fun. Makes me wish I could get a Tremor for a DD.
2010 Non PP Sho. All the factory goodies. (RIP)
2015 MKS Ecoboost. All the factory goodies. (SOLD)
Twintrbskies
______________________________________________________________________________________________________
2010 SHO non-PP, pearl white, Alky Controls Methanol kit-100% meth, tuned with Ortiz Performance, XDI-35, DW300C LPFP, E85, 3-Bar, K&N Drop-In, 160 T-stat, JLT Catch can, Stainless works Catless downpipes, Rear muffler delete with Borla Tips. (not currently using the methanol)
I love my truck, some of the next steps is to dial in the suspension so it's way more car like than truck :) I'll add some helper bags in case of some load required but mostly it's a big car to me.
Next project under way, water to air IC with new IC and reservoir but reusing my V's old HX and pump.
Had a small c notch and custom leaf springs done to level the truck. The ride is SO MUCH BETTER. By leveling the truck the front rides a ton better as well. Next is some double adjustable shocks for the rear and coilovers for the front. Also doing some audio work, I'll post more on that as it occurs.
Thats one Swweeeeeeeet truck!  Z   :)
FearlessAZ
Looks so good. How has the ride been since the gear and converter change?
I need to go test drive one of these some time.
Quote from: FearlessAZ on July 08, 2018, 01:15:57 PM
LOVE IT! I was doing 85 at 2K RPM today just cruising. I need to update the shocks as I had said, do some type of panhard bar and I want to add some helper bags in the rear just in case I need to use the truck. My wife drove with me yesterday and today and she is quite happy with not having the super bouncy ride with an unloaded truck.
Car audio stuff happening, I'll link to my diymobileaudio thread to make it easier but basically doing a Audiofrog active front 3 way with GB60/GB25/GB10 fronts and dual JL cs113tg-tw5-v2 sub boxes on Rockford T1000-bdcp sub and dual T400-4 amps for the front end and GB60/GB10 center channel I'm building. Using a JL MS-8 processor as well.  3D printing custom sail panel speaker mounts for the GB25/GB10's. Long term I'll probably do a blow through with dual JL 13W7's but that will be a long time off.
https://www.diymobileaudio.com/forum/build-logs-project-install-gallery/407357-2014-f150-tremor-regular-cab-short-bed-truck-build.html
Mike Probably got some Sponsors lined Up!  Z   :)
