Quote from: StealBlueSho on March 08, 2017, 07:02:26 AM
Found a temp solution for you if one of the charge pipes has failed...
In all honesty, any luck?
LOL! We swapped the noisemaker pipe, and stock BOV pipes back on yesterday. Brad sent me a revision to the tune to turn stock BOVs back on, and using throttle to control boost again. Loaded that up, and it still isn't making full boost.
When we installed the hotpipes, the intake side connection on the rear turbo was extremely loose, which was weird since I had never messed around in that area. I am wondering if that connection, or the intake side front turbo connection is loose. The only part of the EPP hotpipes still on the car, right now, is the silicone coupler from intercooler to front turbo. I will check that piece as well. I left the stock BOV's VTA but didnt seem to have issue. I can say the noise level for stock BOV VTA is MUCH MUCH quieter than the TiAL.
At this point, if there are no loose connections at the turbos, then it may still be a vacuum line issue. I am going to clean up/delete my additions to the vacuum routing up top to rule that out. I'll double check the reference lines on the turbo wastegates as well, as that could be a likely culprit.
I feel as if the boost solenoid had failed, there would be a code, but there are none. This makes me think it is a loose/missing connection somewhere, rather than a faulty solenoid/sensor. Especially at 15K miles on the car. Hoping we can get it sorted out this afternoon, but we shall see.
