Edgewater Sports Park Drag Test and Tune (March 4th!)
Started by derfdog15, February 24, 2017, 11:45:29 AM
derfdog15
Quote from: FoMoCoSHO on March 01, 2017, 06:20:35 PM
Quote from: derfdog15 on March 01, 2017, 04:12:31 PM
Quote from: FoMoCoSHO on March 01, 2017, 03:43:17 PM
Quote from: AJP turbo on March 01, 2017, 03:09:52 PM
Yes its a showdown...AJP E20 vs E30!
Actually it would be bolted E20 VS unbolted E30
That is true, see if the downpipes, stat, airaid, wastegate mod, and axlebacks on E20 can make up for the added spark (and boost? - not sure if you still run 17psi or are back at 15psi).
If you decide you're going out send me a PM and ill send ya my # so you can find me lol, otherwise I should be able to find the bronzefire SHO pretty easy :D
Betting two mid to low 12 SHOs would really get some panties in a wad, based on my last time out at Edgewater and the reactions I got
What kind of reactions?
Lots of V8 guys (Mainly dodge lol) either talked crapped prior to my runs and then didn't look at me after I ran, or were shocked it was just tune, CAI, and axlebacks (claiming I did something else that I wasn't telling them)
Sean(FoMoCoSHO) did turn down my personal invite a while back.LOL. Z
But Heck its all in Great Fun though,enjoy Fella's.  Z  :thumb:
derfdog15
Quote from: ZSHO on March 02, 2017, 11:19:50 AM
Sorry to hear that Z. I'm betting he was already considering going to Edgewater since its the first race day of the season, and the track is in OH as is he, though IDK how close he is.
Hopefully I'll see him out there, from his logs that I've seen in the past E30 makes me drool a bit :D
Fyi, due to cold weather tomorrows test and tune has been moved to Sunday so I will be unable to attend.
derfdog15
Quote from: FoMoCoSHO on March 03, 2017, 01:33:24 PM
Welp, now I need to reschedule my work, this will be fun...
f8tlSHO
Test and tune here got cancelled also
derfdog15
Quote from: f8tlSHO on March 03, 2017, 01:38:24 PM
That sucks. I checked the forcast earlier, and it had dropped ~10 degrees for tomorrow so its understandable. Sunday is supposed to be a bit above 60 degrees.
f8tlSHO
I wasn't planning on going, just happened to see it got canceled. Planning on the 31st
derfdog15
Quote from: f8tlSHO on March 03, 2017, 01:53:34 PM
Gotcha. I really need to get in a run ASAP so i can hopefully utilize the cool air for my next set of passes as well (when I increase wastegate spring pressure on the regulator)
f8tlSHO
I called out my plant manager here at work.. 13 5.0 mustang 6 spd. Makes 400/400 to the tire..plus a 75 shot. The car is faster than mine, but he never drove a stick car at the track..
derfdog15
Quote from: f8tlSHO on March 03, 2017, 02:00:12 PM
Nice! the AWD will definitely help you out of the hole, unless he has a nice suspension setup. Should be able to take him out of the hole, and keep the gap even if he reels you in a bit once he gets moving out. Will be close for sure, since you are likely making more torque than him to the wheels.
f8tlSHO
Stock suspension on radials, I got him scared...
I bet that's actually a hell of a race...if he is perfect i say he wins....but my money is on you....I guarantee he will miss a shift if its stock shifter.....the radials have me worried...if he is good he can launch with you
The shifter in the stang sucks bad...the nice thing about your auto is how it accelerates through the gear and you never lift....he will pull harder than you but have a big disruption in momentum when he shifts
EFF his rustang or moosestang or whatever he calls it...donkey?
f8tlSHO
Quote from: AJP turbo on March 03, 2017, 02:54:02 PM
Not a stock shifter, I'm gonna toast him off the line...just gotta be able to hold the line long enough once I get the jump. I thought about taking some weight out, but I'd rather race full street weight
f8tlSHO
Not drag radials, I think they are continental dw's
