- Full Member
- Ecobooster
- Logged
Thanks Brad! I'm thinking those wide tires and an e30 tune from you in the spring and I should be in the 12.5 range. I wouldnt mind bumping the boost up alittle for the warm temps as well. You have me at 14. Maybe 16?...maybe......fuel pressure should be fine with the throttle control you utilize. Then I can use the tune I am on now for winter for safety.
Anyhow, Thanks!
p.s. lower and throw the wheels on your Fusion.
2014 SHO nonpp, MDesign intake, PPE catted downpipes, Corsa catback, H&R springs, 170 tstat, 3 bar map sensor, matte black vinyl wrapped chrome trimming, smoke tinted tail lights, 20x9 +35 offset aftermarket wheels on 275/40 R20 Continental Extreme Contact Sports, Powerstop z23 brakes and drilled/slotted rotors, 35% tint, MSD coils, NGK 6510 gapped at 0.26 and AJPturbo 3 bar 93 tune.
12.82 @ 106.6mph w/ 1.82 60"
