Just to clarify, the boost regulator gate ("BOV" as it's called in your diagram) is controlled by boost, not vacuum. Both the charge pipe reference (blue) and an IM reference (red) would be POSITIVE pressure when under boost, not vacuum. In the standard setup, the boost ref is hooked up to a bottom port, which pressurizes the diaphragm under boost and opens the valve.After tuning (both with springs and desired TIP), my boost regulator is not open under normal driving conditions, only when pressure spikes during WOT upshifts or downshifts, otherwise it is closedFrankly, I think you're overcomplicating it. In the standard setup, you just need a boost reference, the spring is sized based off your desired boost, and AJP can fine tune the opening of the gate by changing desired TIP. IMO, by hooking it up the way you show in your diagram (PS, I like how you used a nuclear power plant, lol), you potentially severely limit your tuning options. The lightest spring in the Tial kit is 4.35 PSI, which may be too strong based on the differential between MAP and TIP. You have no kit options to step down, and the next step up is nearly 1.5 PSI. Additionally, there are additional connection points which increase the likelihood for leaks in the long run.Good on you for thinking through some alternate setup options. I guess in the grand scheme of things, I just don't see any benefits to hooking it up the way you proposed as compared to a "standard" setup.Sent from my iPhone using Tapatalk
My concern would be the Gate (BOV) opening during acceleration or while trying to build boost, and bleeding boost off. A BOV stays open at idle/vacuum and closes when in boost, once you get out of boost it opens and relieves the pressure. A wastegate on the other hand is closed at vacuum/building boost, and opens when there is too much boost. As such I would stick to using a wastegate for the regulator mod, and a typical BOV for the BOV. TiAL with a -8PSI spring works very well.
I think you misunderstood my intent.
Quote from: derfdog15 on February 20, 2017, 09:34:19 AMMy concern would be the Gate (BOV) opening during acceleration or while trying to build boost, and bleeding boost off. A BOV stays open at idle/vacuum and closes when in boost, once you get out of boost it opens and relieves the pressure. A wastegate on the other hand is closed at vacuum/building boost, and opens when there is too much boost. As such I would stick to using a wastegate for the regulator mod, and a typical BOV for the BOV. TiAL with a -8PSI spring works very well.With the light spring in my original idea it would bleed boost. I think it might work with a heavier spring, though.A spring type BOV is supposed to be closed at idle and normal driving, only opening to release pressure when you close the throttle. A sequential BOV as I understand it is open at all times under vacuum.
